Visits: Visit Properties
Visits: Visit Properties report elements return information about the type of visit.
Report element |
Description |
Visit Type |
Data type: String Description: The type of visit. Valid types are:
Note: To report only on clinical data, filter this column to include only common and subject visits. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database and decoded for display. |
Start Hours |
Data type: Numeric Description: Number of hours from the subject enrollment to the start of the visit. This number is specified in the study design code and is used to create the proposed schedule of visits shown in the Visit Calculator when a subject is enrolled. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Is Scheduled Visit |
Data type: Y/N Description: Indicates whether the visit is a scheduled visit. Scheduled visits occur in a fixed relationship to the beginning of enrollment in a study by a subject. Scheduled visits start a specified number of hours after enrollment. Valid values are:
Is Repeating Visit |
Data type: Y/N Description: Indicates whether the visit is a repeating visit. Repeating visits are those that occur multiple times within a study. Repeating visits are always unscheduled. Valid values are:
Is Dynamic Visit |
Data type: Y/N Description: Indicates whether the visit is a dynamic visit. Dynamic visits are created automatically when subject data satisfies certain criteria that you test by attaching a rule to a form item. Valid values are:
Dynamic Projected Start Hours |
Data type: Numeric Description: The number of hours after the study starts that this visit is scheduled to take place. This value is used for dynamic visit scheduling. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Visit Order |
Data type: Numeric Description: A number that indicates the relative order of the visit within the study. Note: Use Visit Order to sort visits in a report. This is helpful when the visit order is not implied in the Visit Mnemonic or Visit Name. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Design Note |
Data type: String Description: Optional text containing special information about the visit, specified in the study design code. This information is for documentation only and is not displayed in the InForm application. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
