Items
Items report elements return metrics on the items in your study.
Report element |
Description |
Item Name |
Data type: String Description: The itemset header text, as specified in the study design code. Access to this data can be restricted in the InForm application. When users who do not have access to this data run a report with this report element, the resulting report displays a series of asterisks (********) rather than the actual itemset header text. InForm items that have never had data will not appear on reports that pair Item Name with Form Mnemonic or Form Name. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Item Question |
Data type: String Description: Text of the question or prompt that instructs the user to enter specific clinical data. Access to this data can be restricted in the InForm application. When users who do not have access to this data run a report with this report element, the resulting report displays a series of asterisks (********) rather than the actual item question. InForm items that have never contained data will not appear on reports that pair Item Question with Form Name or Form Mnemonic. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Reason for Change |
Data type: String Description: Text that explains the reason for the most recent clinical data change (if any) for the item. Text appears here only when the clinical data for the item has been changed since initial entry. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Incomplete Reason |
Data type: String Description: Text that explains why the item was marked Incomplete. Text appears here only when the item has been marked Incomplete. Use this report element with the Subject Number report element to see incomplete reason text broken out by subject. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Status Change User |
Data type: String Description: The user name of the InForm user who made the most recent change to the status of the item. A change to the SV status of the item is considered a status change for the item. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Data Change User |
Data type: String Description: The user name of the InForm user who made the most recent change to the item. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
