Items: Item Properties
Items: Item Properties report elements let you report on types of items.
Report element |
Description |
Is Required |
Data type: Y/N Description: Indicates whether the item requires a value for the form to be considered data entry complete. Valid values are:
Note: Itemset items cannot be required. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database and decoded for display. |
Is SV Required |
Data type: Y/N Description: Indicates whether the item requires source verification.
An item is considered SV Required only if it is marked SV Required. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database and decoded for display. |
Is SV Selected |
Data type: Y/N Description: Indicates whether the item has been selected for source verification.
Is Critical Override |
Data type: Y/N Description: Indicates whether the critical setting for the item in the study design was overridden using the Central Designer application or the InForm user interface.
Is Blank |
Data type: Y/N Description: Indicates whether the item is blank.
