My report contains empty cells
Cells in reports might be blank because:
- Data was entered for an item, then deleted.
- Data wasn't entered for an item.
- An item is set to be populated by a calculation rule, but data wasn't entered for an item that the rule requires.
For example, if the DOV item does not contain data, the DOV to Form Started column in the CRF Cycle Time Detail by Site standard report is blank.
- You created a report on associated forms, and:
- The report elements in the report are not from associated forms.
- The report contains data from more than two associated forms.
- You created a report with an itemset and a non-repeating section, and either of them was deleted. When this happens, the columns in the report are empty for subjects that did not have data in the deleted study object before it was deleted.
- You created a report with report elements that are stored in different database tables, and data wasn't entered for one of the report elements for one of the subjects in the report.
For example, if you add items from the Demography form and an item from the Baseline Vital Signs form, but for one subject in the report, data has not been entered for the Vital signs item on the Baseline Vital Signs form, you might see blank columns or columns populated with N/A.
