My report contains N/A in some cells
When you create a report with clinical data, the text N/A might appear for the following:
- Items or controls that are not started.
- Items or controls that are blank; that is, data for the item or control has been cleared.
- Items or controls that are blinded; that is, you don't have the right to see the data.
- Items or controls that are marked as Unknown.
- Items or controls with data entered for sites you are not associated with.
- Items or controls that exist on a repeating form, if you applied a filter to exclude their data. For example, if you applied a filter on an Adverse Event form so that only the Depression adverse event appears in the report, N/A appears in the rows for all other adverse events.
