Columns that you can reuse in all of your studies
If you want to create a report that you can run for all of your studies, use only study management query elements and topics, which appear in the <study name> InForm Trial Management section of the tree. Since every study contains the same set of study management query elements and topics, you can reuse the report and run it against any study.
