Forms: Review States
Forms: Review States report elements return the custom review state with which each form in the report is associated.
You create custom review states and stages for the Data Viewer using the Central Designer application. You can define as many as five custom review states, and each custom review state must include three stages. If you do not define custom review states and stages for your study, the associated report elements do not appear in the Query Studio tree. For more information, see the Central Designer User Guide.
Note: This folder contains study-specific clinical data. It only appears for the Forms report topic if you select the study-specific clinical package on the Select a package page when accessing the Query Studio workspace.
Report element |
Description |
Review state name |
Data type: String Description: The custom review state associated with the form, if custom review states are defined for the study. Data source: Calculated in the clinical data model. |
