Forms: Review States Counts
Forms: Review States Counts report elements return the number of forms that are associated with each custom review state and stage in a study. The folder contains one measure element for each custom review state and stage combination.
You create custom review states and stages for the Data Viewer using the Central Designer application. You can define as many as five custom review states, and each custom review state must include three stages. If you do not define custom review states and stages for your study, the associated report elements do not appear in the Query Studio tree. For more information, see the Central Designer User Guide.
Note: This folder contains study-specific clinical data. It only appears for the Forms report topic if you select the study-specific clinical package on the Select a package page when accessing the Query Studio workspace.
Report element |
Description |
Review state name ~ Review stage name |
Data type: Numeric Description: The number of forms associated with a stage in a custom review state. Data source: Derived and stored in the Reporting and Analysis database. |
