CRF Frozen Status
This report shows the current frozen status of forms.
Link to form items
Click the value in the Form column to link directly to the form in InForm.
Column descriptions
Column descriptions
Column |
Description |
Country |
Data type: String Description: The country in which a site is located, as entered in the InForm Administration interface. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Site Mnemonic |
Data type: String Description: An abbreviation that identifies the site associated with the form, as entered in the InForm Administration interface. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Subject Number |
Data type: String Description: Number that identifies the subject associated with the form. This number may be changed after the subject is enrolled, if the study is configured to require a unique subject ID for a study or site. Data source: Replicated from the InForm Transactional Database to the Reporting and Analysis database. |
Visit Mnemonic |
Data type: String Description: Abbreviation of the visit title for the visit the form was filled out in, as specified in study design code. For CRF visits, this name appears at the top of a collection of forms in the visit timeline. The visit mnemonic may not be a unique identifier. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
DOV |
Data type: Date/Time Description: The date that is recorded in a standard Date of Visit control in the InForm application. Data type: Clinical Note: This report element assumes that your study was developed using a specific design for the DOV controls. UUIDs:
Section—BD991BBE-B0A4-11D2-80E3-00A0C9AF7674 |
Form Mnemonic |
Data type: String Description: A short name or abbreviation for the form, as specified in the study design code. Short name or abbreviation for the form, as specified in the study design code. This name appears on the Visit Navigation tab and is used to access a specific form in the InForm application. To open the form in InForm, log in to InForm if prompted, then click the link in this column. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Form Index |
Data type: String Description: For repeating forms, a numeric ordinal value that identifies the instance of the form. For non-repeating forms, the value is 1. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Details |
Data type: String Description: The following information about the current frozen status of the form.
