CRF Signature Status Report
This report shows the signature status of forms that require signatures.
Column descriptions
Column descriptions
Column |
Description |
Country |
Data type: String Description: The country in which a site is located, as entered in the InForm Administration interface. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Site Mnemonic |
Data type: String Description: An abbreviation that identifies the site associated with the form, as entered in the InForm Administration interface. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Subject Number |
Data type: String Description: Number that identifies the subject associated with the form. This number may be changed after the subject is enrolled, if the study is configured to require a unique subject ID for a study or site. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Visit Mnemonic |
Data type: String Description: Abbreviation of the visit title for the visit the form was filled out in, as specified in study design code. For CRF visits, this name appears at the top of a collection of forms in the visit timeline. The visit mnemonic may not be a unique identifier. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
DOV |
Data type: Date/Time Description: The date that is recorded in a standard Date of Visit control in the InForm application. Data type: Clinical Note: This report element assumes that your study was developed using a specific design for the DOV controls. UUIDs:
Section—BD991BBE-B0A4-11D2-80E3-00A0C9AF7674 |
Form Mnemonic |
Data type: String Description: Short name or abbreviation for the form, as specified in the study design code. This name appears on the Visit Navigation tab and is used to access a specific form in the InForm application. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Form Index |
Data type: String Description: For repeating forms, a numeric ordinal value that identifies the instance of the form. For non-repeating forms, the value is 1. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Type |
Data type: String Description: The Signature Type for the given report row:
Details |
Data type: String Description: The following information about the signature status of the form.
