CRF Site Performance Summary by Site
This report shows the average amount of time between study milestones, such as from visit start, to initial data entry, to form complete, and includes aging information for incomplete forms organized by site.
Tip: For the best performance, do not select any optional filters on the Selection Criteria page.
Graphs
Two bar graphs appear on the first page of the CRF Site Performance Summary by Site report. The first graph plots, for the selected sites, the median number of days from DOV to form started and the median number of days from DOV to form completed. The second graph plots the number of incomplete forms, by time period, for the selected sites.
Subtotals and totals
- Subtotals—By Country.
- Min—Lowest minimum value for any site in the country.
- Max—Highest maximum value for any site in the country.
- Median—No value.
- Totals—Overall cycle time totals.
- Median—No value.
Drill-down reports
You can click a value in the Site Mnemonic column to drill down to the CRF Cycle Time Detail by Site report.
Column descriptions
Column descriptions
Column |
Description |
Country |
Data type: String Description: The country in which a site is located, as entered in the InForm Administration interface. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Site Mnemonic |
Data type: String Description: An abbreviation that identifies a site, as entered in the InForm Administration interface. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
DOV to Forms Started (Days): Min, Max, Median |
Data type: Numeric Description: The number of days from the date entered on the DOV form to the first day on which any data entry activity (item data, comments, or queries) started. For each visit, this section displays:
Note: This report element assumes that your study was developed using a specific design for the DOV controls. UUIDs:
Data source: Minimum, maximum, and median values are derived for the report, and are not stored in the Reporting and Analysis database. |
DOV to Forms Completed (Days): Min, Max, Median |
Data type: Numeric Description: The number of days from the date entered on the DOV form to the most recent date on which all of the required items on the form contain data. For each visit, this section displays:
Forms Completed to Forms SV Complete (Days): Min, Max, Median |
Data type: Numeric Description: The number of days from the earliest date on which the form was complete to the most recent date when the form was marked Verified. A form is considered Verified if one of the following is true:
If none of the items on the form require source verification, the InForm application marks the form Verified. For each visit, this section displays:
Forms Completed to Forms Locked (Days): Min, Max, Median |
Data type: Numeric Description: The number of days from the earliest date on which the form was complete to the most recent date when the form was locked. For each visit, this section displays:
Incomplete (from DOV) Forms Count (Days) |
Data type: Numeric (Percentage) Description: The total count of all forms across all subjects that have been incomplete for specific ranges of calendar days after the date of visit. You specify the aging interval (in days) on the report prompt page. For example, if you specify 7, the resulting report shows the number of forms that have been incomplete for:
How calculated: This value displays as a whole number, followed by a percentage of the total incomplete form count. The percentage is calculated as follows: [count of incomplete forms within the aging interval] * 100 / [count of incomplete forms] Note: This report element assumes that your study was developed using a specific design for the DOV controls. UUIDs:
Data source: Derived for the report; not stored in the Reporting and Analysis database. |
