Historical Login Report
This report shows the login history within a selected date range. There are also Query Studio report topics that you can use to create a report that shows user status and group membership information.
For more information, see User Info: Historical User Info.
Column descriptions
Column descriptions
Column |
Description |
Login Date/Time |
Data type: String Description: Login date/time value. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Username |
Data type: String Description: User name of the user. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
First name |
Data type: String Description: First name of the user. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Last name |
Data type: String Description: Last name of the user. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Country |
Data type: String Description: Country in which a user is located, as entered in the InForm Administration interface. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Rights Group |
Data type: String Description: Rights group to which the user belongs. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
User Type |
Data type: String Description: User type. For example, Sponsor. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
