User Info: Historical User Info
Historical User Info report elements allow you to see status information and group membership changes for users.
Note: To include the current first name, last name, and rights group for a user, use report elements from the User Info: Users folder.
There is also a standard report that shows the login history for a study within a selected date range.
For more information, see Historical Login Report.
Report element |
Description |
User ID |
Data type: String Description: The user ID of the InForm user whose status or group membership changed. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Change Type |
Data type: String Description: Displays the following text, describing the type of change the user has undergone:
Change Type Description |
Data type: String Description: Additional information about the type of change the user has undergone.
Change Date |
Data type: Date/Time Description: Date and time when the user status or group membership change took place. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Change Username |
Data type: String Description: User name of the user who updated the status or group membership information for the user whose status or group membership changed. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Reason for Change |
Data type: String Description: The reason for the user status or group membership change, as generated by the InForm application. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Change Group Name |
Data type: String Description: For users whose group membership information changed, the group name to which the user was added or from which the user was removed. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. Note: If the user group membership information did not change, data does not appear in this column. |
Change Group Type |
Data type: String Description: For users whose group membership information changed, the group type of the group to which the user was added or from which the user was removed. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. Note: If the user group membership information did not change, data does not appear in this column. |
