Predefined filters
Use predefined filters to narrow results in your Query Studio reports. These filters are shipped with the InForm application and can be used in all reports.
Note: You can also create filters to be used within reports. Each user-created filter is saved with the report in which it was created. The filter can be used only with that report and cannot be used globally across multiple reports.
