Previous Topic
Next Topic
Book Contents
Delete or undelete an Add Entry row
To delete a whole Add Entry row:
  1. Click the row number in the far-left column of the row.
  2. In the Reason for change field, select or enter a reason for the deletion.
  3. Click Delete.
    The items in the deleted row are crossed out on the form.
To undelete a whole Add Entry row:
  1. Click the row number in the far-left column of a row with crossed-out items.
  2. In the Reason for change field, select or enter a reason for undeleting.
  3. Click Undelete.
  4. If the data in the Add Entry row is mapped to a dynamic grid, which is used to collect related data on a single form, you must re-add the data to the dynamic grid. For more information, see Collect related data from multiple forms.
Send Feedback
