Previous Topic
Next Topic
Book Contents
Why would a screening fail, and what can I do about it?
The screening form is incomplete.
Complete the form, and then click Submit.
The candidate is ineligible for the study.
Check the data and make corrections if necessary. To correct a data value:
  1. Click the entered value.
  2. On the Data Value(s) page, type the correct value and select or type a reason for change.
  3. Click Submit.
  4. Click OK.
  5. Click Return to go back to the Screening form.
Send Feedback
