The process of configuring subject data edits
During configuration, you complete each of these tasks:
- In the AppBlock Designer, enable each field to be editable.
An Oracle representative must perform this task.
- In IRT, authorize subject data edits for the study.
An Oracle representative must perform this task. This procedure switches on the ability to change subject information in a study after a transaction is complete.
- In IRT, identify editable fields and permissions.
An Oracle representative must perform this task. This procedure identifies which fields in the study are editable, and the level of approval assigned to each field.
You can enable or disable editing of each field for a transaction. You can also set the approver roles and approval level for each field: no approval, one level of approval, or two levels of approval.
A subject affected by a request for approval is locked (
) until the request is reviewed and either approved or rejected.
