Identifying data entry fields in AppBlock Designer
This procedure identifies the data entry fields in the study so they can be configured for subject data edits in IRT.
IRT collects the data entry fields for the study from the AppBlock Designer. The AppBlock Designer is an internal Oracle tool for designing clinical studies. IRT collects study design configuration properties from the AppBlock Designer and displays it in the user interface, where you can configure, view, and add data to the study.
IRT only collects data entry fields. It does not collect calculated fields even if they are based on data entry fields. For example, if BMI is calculated from Height and Weight, IRT can only collect Height and Weight as editable fields, but not BMI.
An Oracle representative must perform this procedure for each editable field prior to deploying the trial. For more information, see Configuring subject data edits.
- Log on to AppBlock Designer.
- Select the Sponsor.
- Select the Protocol.
- Select the AppBlock function for the transaction.
- Click Load Workflow.
- In the flowchart, double-click the step containing the field you want to make editable.
- Click the IRT Developer tab.
- Select the button to the right of the Name AppMessage field.
- In the WebMessage textbox, type a name for the field as it should display in the IRT user interface.
- Click OK.
- Click OK again.
- Repeat steps 6 - 12 for each field that should be editable in this AppBlock flow.
