3 Application Areas
This is a public interface for Application Area-related operations— creating, modifying, and removing Application Areas; as well as copying and moving object definitions into an Application Area. It contains the following:
Parent topic: Object APIs
Define and Modify Application Areas
- Create an Application Area
- Modify an Application Area
- Remove an Application Area
- Copy Objects into an Application Area
- Move Objects into an Application Area
Parent topic: Application Areas
Use this API to create a new Application Area.
Name
CDR_PUB_DF_APPLICATIONAREA.CreateApplicationArea
Signature
PROCEDURE CREATEAPPLICATIONAREA( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE, PI_DEFCLASSIFICATIONCOLL IN CDR_CLASSIFICATIONS_COLL );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PIO_SOURCECDRNAMING (Mandatory) This is a parameter of table type
CDR_NAMING_VERSION_OBJ_TYPE. Enter values for the Application Area you want to create.
The following attributes are required: company_id, namespace_obj_id, namespace_obj_ver, object_type_rc. for object_type_rc enter $objtypes$applarea.
- PI_DEFCLASSIFICATIONCOLL(Optional) By default the new Application Area is classified according to the subtype you assigned it in the CDR_NAMING_VERSION_OBJ_TYPE. If you want to override the default classifications for one or more classification levels, use this parameter. This is a collection of CDR_CLA_OBJ_TYPEs, which have 5 attributes, including CLA_LEVEL_ID and CLASSIFICATION_ID. If you want the Application Area to inherit its classifications for a particular level from its parent Domain, enter the classification level ID and, for the CLASSIFICATION_ID, enter 0 (zero). If you want to explicitly assign one or more terms for a particular level, initialize a CDR_CLA_OBJ_TYPE for each term, entering the classification level ID and, for the CLASSIFICATION_ID, the term ID. The PAR_ attributes are not relevant to Application Areas. Do not enter any values for them.
Parent topic: Define and Modify Application Areas
Use this API to modify the name or description of an existing Application Area.
Name
CDR_PUB_DF_APPLICATIONAREA.ModifyApplicationArea
Signature
PROCEDURE MODIFYAPPLICATIONAREA( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE );
Parameters
This API has standard parameters (see Standard Parameters) as well as the following:
PIO_SOURCECDRNAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the Application Area you want to modify and for the attributes you want to modify. You can modify the name and description. All attributes are required.
Use this API to remove one or more Application Areas and all its/their contents.
Name
CDR_PUB_DF_APPLICATIONAREA.RemoveApplicationAreas
Signature
PROCEDURE REMOVEAPPLICATIONAREAS( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_BASEOBJCOLL IN OUT CDR_BASE_OBJ_COLL );
Parameters
PI_BASEOBJCOLL Mandatory) This is a collection of CDR_BASE_OBJ_TYPEs. For each Application Area that you want to remove (including all its contents), initialize a CDR_BASE_OBJ_TYPE and then extend the collection.
The following attributes are required: COMPANY_ID, OBJ_ID, OBJ_VER, OBJECT_VERSION_NUMBER, NAMESPACE_OBJ_ID, NAMESPACE_OBJ_VER.
Use this API to copy object definitions into an Application Area.
Name
CDR_PUB_DF_APPLICATIONAREA.CopyObjectIntoAA
Signature
PROCEDURE COPYOBJECTINTOAA( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_CDRBASEOBJCOLL IN OUT CDR_BASE_OBJ_COLL, PI_CDRTARGETCONTAINEROBJECT IN OUT CDR_BASE_OBJ_TYPE, PI_CHECKINFLAG IN VARCHAR2 );
Parameters
- PI_CDRBASEOBJCOLL (Mandatory). This is a collection of CDR_BASE_OBJ_TYPEs.
For each object that you want to copy into the Application Area, initialize a
- PI_CDRTARGETCONTAINEROBJECT (Mandatory). This is a parameter of table type
CDR_BASE_OBJ_TYPE. Enter values to identify the Application Area into which you want to
copy objects.
The following attributes are required: COMPANY_ID, OBJECT_ID, OBJECT_VER,NAMESPACE_OBJ_ID, NAMESPACE_OBJ_VER, OBJECT_VERSION_NUMBER.
- PI_CHECKINFLAG (Mandatory). Enter $YESNO$NO if you want any checked-out copied objects to remain checked out, or $YESNO$YES if you want the system to check them in after the copy operation.
Use this API to move LSH objects into an Application Area.
Name
CDR_PUB_DF_APPLICATIONAREA.MoveObjectIntoAA
Signature
PROCEDURE MOVEOBJECTINTOAA( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_CDRBASEOBJCOLL IN OUT CDR_BASE_OBJ_COLL, PI_CDRTARGETCONTAINEROBJECT IN OUT CDR_BASE_OBJ_TYPE );
Parameters
- PI_CDRBASEOBJCOLL (Mandatory) This is a collection of CDR_BASE_OBJ_TYPEs.
For each object that you want to move into the Application Area, initialize a
- PI_CDRTARGETCONTAINEROBJECT (Mandatory) This is a parameter of table type
move objects.
