34 Public Views
Public views fetch data only if the sys_context setting is enabled by an Oracle DMW login through the API. Public views do not have explicit object-level security checking.
This section includes the public views for the following APIs:
- Clinical Data Model Views
- Codelist Views
- Discrepancy Views
- Validation Checks Views
- Transformation Views
- Thesaurus Management System-Related Views
- Generic Business Area Views
- Security-Related Views
- Snapshot Label View
Parent topic: Public Views
This section contains public views related to clinical data models.
- DME_DATAMODEL_V
- DME_TABLES_V
- DME_COLUMNS_V
- DME_CONSTRAINT_V
- DME_CONSTRAINT_COLS_V
- DME_LOV_VALUES_V
- DME_SDTM_COL_IDENTIFIERS_V
- DME_SDTM_TAB_IDENTIFIERS_V
DME_DATAMODEL_V
Use this view to see study and library clinical data model definitional details.
Parent topic: Clinical Data Model Views
DME_TABLES_V
Use this view to see clinical data model table definitional details.
DME_COLUMNS_V
Use this view to see clinical data model table column definitional details.
DME_CONSTRAINT_V
Use this view to see clinical data model table constraint definitional details.
Use this view to see clinical data model table constraint column definitional details.
DME_LOV_VALUES_V
Use this view to see clinical data model table check constraint lists of values.
Use this view to see SDTM column identifier definitional details.
Use this view to see SDTM table identifier definitional details.
Codelist Views
This section contains public views related to codelists.
DME_PUB_CODELIST_VALUES_V
Use this view to see codelists with their values.
Parent topic: Codelist Views
DME_PUB_XFM_FILTER_VALUES_V
Use this view to see the codelist codes and values associated with a column in a DMW table that is used as a pivot column in a transformation.
Discrepancy Views
This section contains public views related to discrepancies.
DME_PUB_DISCREPANCIES_V
Use this view to see discrepancy details, including the study, clinical data model, table, and column against whose data the discrepancy was raised.
Parent topic: Discrepancy Views
DME_PUB_DISC_SEND_ERRORS_V
Use this view to help figure out why new or updated discrepancies created by validation checks or TMS that should be sent to InForm (or another integrated EDC system) failed to be sent. It contains a row for each Send failure.
This section contains public views related to validation checks.
DME_PUB_VC_BATCHES_V
Use this view to see validation check batch definitional details. The following query returns the validation check batches that read from a given clinical data model:
Select * from DME_PUB_VC_BATCHES_V where SRC_MODEL_COMPANY_ID = <company_id> and SRC_MODEL_OBJ_ID =<obj> and SRC_MODEL_OBJ_VER = <ver>;
The following parameters are required for operations related to a batch; for example, update, check in, uncheck, check out, install, and so on.
BATCH_MAP_COMPANY_ID BATCH_MAP_OBJ_ID BATCH_MAP_OBJ_VER BATCH_MAP_NS_OBJ_ID BATCH_MAP_NS_OBJ_VER BATCH_MAP_OBJECT_VER_NUM
Parent topic: Validation Checks Views
DME_PUB_VC_DETAILS_V
Use this view to see validation check details. The following query returns the validation checks available for a given validation check batch.
Select * from DME_MT_VC_DETAILS_V where vc_company_id= <vc_batch_map_company_id> and VC_BATCH_MAP_OBJ_ID = <vc_batch_map_id> and <vc_batch_map_version> between VC_MAP_NS_START_OBJ_VER and VC_MAP_NS_END_OBJ_VER;
This section contains public views related to transformations.
- DME_PUB_DF_XFORM_MAP_V
- DME_PUB_DF_MAP_ENTITY_V
- DME_XFM_FILTER_VALUES_V
- DME_PUB_XFM_SOURCE_TABLES_V
- DME_PUB_XFM_SOURCE_COLUMNS_V
- DME_ PUB_XFM_TARGET_TABLES_V
- DME_ PUB_XFM_TARGET_COLUMNS_V
- DME_ PUB_XFM_AUTOMAPS_V
- DME_PUB_XFM_COL_AUTOMAPS_V
- DME_PUB_XFM_CUSTOM_PROGRAMS_V
- DME_PUB_XFM_EXPR_STDFUNC_V
- DME_PUB_XFM_EXPR_STATIC_PKGS_V
Use this view to see transformation map details.
Parent topic: Transformation Views
Use this view to see source database tables involved in table mappings.
Use this view to see details of columns from the source database tables, which are mapped to columns in target database table.
Use this view to see details for target database tables involved in table mappings.
Use this view to see details of the columns from the target database tables, to which one or more source table are mapped.
Use this view to see details of the available auto maps at table level.
Use this view to see details of available auto maps at column level.
Use this view to see the details of the available custom programs.
Use this view to see supported standard Oracle Scalar functions and their respective function return types. You can refer to these functions while creating the expressions.
Use this view to see the user defined LSH stored functions Scalar functions and their respective details. You can check available user-defined functions from this view and can use these functions while dealing with expressions.
This section contains public views related to TMS integration with Oracle DMW.
DME_PUB_TMS_STUDY_DOM_ELEMS_V
Use this view to see TMS domains and the studies they are assigned to in DMW.
Parent topic: Thesaurus Management System-Related Views
DME_PUB_TMS_SETS_V
Use this view to see TMS Sets created to derive data from TMS to DMW.
DME_PUB_TMS_SET_COLS_V
Use this view to see TMS Set columns and the information they derive from TMS to the DMW table columns they are mapped to.
This section contains public views related to generic business areas (for data visualizations).
CDR_PUB_GENERIC_BA_V
Use this naming view to retrieve all the Generic Visualization Business Area Instances on which a user has privileges to read data.
Parent topic: Generic Business Area Views
CDR_PUB_GENERIC_BA_TABLES_V
Use this view to retrieve the Table instance details for a given GV BAI.
This section contains public views related to security.
CDR_PUB_UG_ROLES_V
Use this view to see roles assigned to user groups.
Parent topic: Security-Related Views
CDR_PUB_USER_UG_ROLES_V
Use this view to see users assigned to roles in user groups.
CDR_PUB_SUBTYPE_OPR_ROLES_V
Use this view to see operations on object subtypes assigned to roles.
CDR_PUB_OBJ_UG_V
Use this view to see user group assignments to objects.
Snapshot Label View
This section contains a public views related to snapshot labels.
CDR_PUB_SNAPSHOT_LABEL_V
Use this view to see snapshot labels and the tables they are assigned to.
Parent topic: Snapshot Label View
