11 Report Sets
- Create and Modify Report Set Entries
- Create and Modify Report Sets
- Create and Modify Overlay Template Definitions
- Report Set Overlay Template
Parent topic: Object APIs
- Create a Report Set Entry
- Add and Modify an Entry
- Copy a Report Set Entry into Another
- Modify a Report Set Entry
- Move a Report Set Entry into Another
- Reorder Report Set Entries in a Parent Report Set
- Find if a Report Set is Checked Out
- Check Unique and Strict Numbering in a Report Set
- Identify if a Report Set Contains Child Entries
- Find if a User has Modify Permission
- Remove an Object from a Report Set Entry
- Remove a Report Set Entry
- Get a Report Set Name
- Get a Title
- Get a Chapter Number
- Get a Parent Number
- Get a List of Report Set Entry Titles
- Get All RSE Titles in a Report Set
- Get Attribute Values Derived from a Parent
- Get the Lowest Entry Number
- Get the Total Number of Report Set Entries
- Create a Narrative
- Update a Narrative
- Delete a Narrative
- Check if Copying Retains Valid Numbering in a Target Report Set
- Check if a Move Retains Valid Numbering in a Target Report Set
- Check if a Move Retains Valid Numbering in the Parent Report Set
- Check if Removal Retains Valid Numbering in a Parent Report Set
- Check if Reordering Retains Valid Numbering in a Parent Report Set
- Unassign a Planned Output
Parent topic: Report Sets
Use this API to create a Report Set Entry within a Report Set or another Report Set Entry.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.CreateReportSetEntry
Signature
PROCEDURE CREATEREPORTSETENTRY( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE, PI_CDRRSENTRY IN OUT CDR_RS_ENTRY_OBJ_TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PIO_SOURCECDRNAMING (Mandatory) This is a parameter of table type
CDR_NAMING_VERSION_OBJ_TYPE. Enter values for the new Report Set Entry. Use the NAMESPACE
attributes to identify the Report Set or Report Set Entry in which you want to create the
new Report Set Entry. For OBJECT_TYPE_RC enter $OBJTYPES$REPORTSETENTRY.
The following attributes are required: COMPANY_ID,NAME,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER.
- PI_CDRRSENTRY (Mandatory) This is a parameter of table type
CDR_RS_ENTRY_OBJ_TYPE that contains attributes specific to Report Set Entries. Enter
The following attributes are required: COMPANY_ID,OBJ_ID,OBJ_VER,ENTRY_NUMBER,POSITION,UNIQUE_NUMBERING_FLAG_RC,STRICT_NUMBERING_FLAG_RC,PRE_NARRATIVE_ID,POST_NARRATIVE_ID, OMIT_FROM_INSTALL_FLAG_RC,TITLE,DELIMITTER,PREFIX,POSTFIX, PLACEHOLDER_FLAG_RC, VOLUME_BREAK_FLAG_RC,PI_OBJ_ID,PO_COMPANY_ID,PO_OBJ_ID,ENTRY_NUMBER_FLAG_RC,PARENT_FLAG_RC,PREFIX_FLAG_RC,POSTFIX_FLAG_RC,DELIMITER_FLAG_RC.
Parent topic: Create and Modify Report Set Entries
Use this API to add and/or modify one or more Report Set Entries within the same parent Report Set Entry or Report Set definition. For a new RSE to be added, the user can use any number for the OBJ_ID and OBJ_VER like 0 and a positive number.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.AddNewAndModifyEntries
Signature
PROCEDURE ADDNEWANDMODIFYENTRIES( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_CDRRSENAMEENTRYCOLL IN OUT CDR_RS_ENTRY_NAME_COLL, PIO_CDRRSECOLL IN OUT CDR_RS_ENTRY_COLL, COMPANYID IN CDR_NAMING_VERSIONS.COMPANY_ID%TYPE, NSOBJID IN CDR_NAMINGS.NAMESPACE_OBJ_ID%TYPE, NSOBJVER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE, OBJSUBTYPEID IN CDR_NAMINGS.OBJECT_SUBTYPE_ID%TYPE );
Parameters
- PI_CDRRSENAMEENTRYCOLL (Mandatory) This is a collection of
CDR_RS_ENTRY_NAME_OBJs. For each Report Set Entry that you want to modify or add, initialize
a CDR_RS_ENTRY_NAME_OBJ and then extend the collection.
If you are modifying an RSE, enter its existing values.
If you are creating a new RSE, enter 1 for OBJ_VER and enter a number for the OBJ_ID (it must be unique within the collection). The following attributes are required: NAME,ENTRY_NUMBER,OBJ_ID,OBJ_VER.
- PIO_CDRRSECOLL (Mandatory) This is a collection of CDR_RS_ENTRY_OBJ_TYPEs.
For each Report Set Entry that you want to modify or add, initialize a CDR_RS_ENTRY_OBJ_TYPE
(with new values for the attributes you want to change, if you are modifying existing
Entries) and then extend the collection.
The following attributes are required: COMPANY_ID,OBJ_ID,OBJ_VER,ENTRY_NUMBER,POSITION,UNIQUE_NUMBERING_FLAG_RC,STRICT_NUMBERING_FLAG_RC,PRE_NARRATIVE_ID,POST_NARRATIVE_ID, OMIT_FROM_INSTALL_FLAG_RC, TITLE, DELIMITTER, PREFIX, POSTFIX, PLACEHOLDER_FLAG_RC, VOLUME_BREAK_FLAG_RC,PI_OBJ_ID,PO_COMPANY_ID,PO_OBJ_ID,ENTRY_NUMBER_FLAG_RC,PARENT_FLAG_RC,PREFIX_FLAG_RC,POSTFIX_FLAG_RC,DELIMITER_FLAG_RC.
You must enter an single integer Entry Number for each Report Set Entry. The API does not create entry numbers for you, but it does enforce the unique and strict numbering settings for the Report Set or Report Set Entry - COMPANYID (Mandatory) Enter your COMPANY_ID.
- NSOBJID (Mandatory) Enter the OBJ_ID of the Report Set or Report Set Entry within which you want to add or modify Report Set Entries.
- NSOBJVER (Mandatory) Enter the OBJ_VER of the Report Set or Report Set Entry within which you want to add or modify Report Set Entries.
- OBJSUBTYPEID (Optional) If you are adding or modifying top-level Report Set
Entries, enter the subtype ID of the Report Set.
If you are adding or modifying Report Set Entries contained in another Report Set Entry, leave this parameter null.
Use this procedure to copy one or more Report Set Entries into another Report Set Entry. The target Report Set Entry may or may not belong to the same Report Set hierarchy.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.CopyObjectsIntoReportSetEntry
Signature
PROCEDURE COPYOBJECTSINTOREPORTSETENTRY( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_CDRBASEOBJCOLL IN OUT CDR_BASE_OBJ_COLL, PIO_TARGETBASEOBJ IN OUT CDR_BASE_OBJ_TYPE, RENUMBER IN VARCHAR2, PI_COPYPRGASSGNMT IN VARCHAR2 );
Parameters
- PIO_CDRBASEOBJCOLL (Mandatory) This is a collection of CDR_BASE_OBJ_TYPEs.
For each Report Set Entry that you want to copy into another Report Set Entry, initialize a CDR_BASE_OBJ_TYPE and then extend the collection.
The following attributes are required: COMPANY_ID,OBJ_ID,OBJ_VER,OBJECT_VERSION_NUMBER,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER.
- PIO_TARGETBASEOBJ (Mandatory) This is a parameter of table type
CDR_BASE_OBJ_TYPE. Enter values to identify the Report Set Entry into which you want to copy
other Report Set Entries.
- RENUMBER (Mandatory) Enter 'Y' for copied Report Set Entries to appropriately numbered in their new location.
- PI_COPYPRGASSGNMT (Mandatory) When copying Report Set Entries, enter 'Y' to copy Program instances currently assigned to the Report Set Entries, their Planned Output assignments and mappings. Enter 'N' to avoid copying these Program instances in which case, all Planned Output assignments are lost.
Use this API to modify a Report Set Entry.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.ModifyReportSetEntry
Signature
PROCEDURE MODIFYREPORTSETENTRY( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE, PI_CDRRSENTRY IN OUT CDR_RS_ENTRY_OBJ_TYPE );
Parameters
- PIO_SOURCECDRNAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSIONS_OBJ_TYPE that contains CDR Naming Version attributes. Enter values to identify the Report Set Entry that you want modify and enter new values for the attributes you want to modify. You can change the name and description. All attributes are required.
- PI_CDRRSENTRY (Mandatory) This is a parameter of table type CDR_RS_ENTRY_OBJ_TYPE. Enter values to identify the Report Set Entry that you want to modify and enter new values for the attributes you want to modify. You can change the Entry and Position numbers, the Strict and Unique Numbering flags, the Omit from Install flag, the Title, Delimiter, Prefix, Postfix, Placeholder flag and Volume Break flag values. All attributes are required.
Use this API to move one or more Report Set Entries into another Report Set Entry.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.MoveObjectsIntoReportSetEntry
Signature
PROCEDURE MOVEOBJECTSINTOREPORTSETENTRY( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_CDRBASEOBJCOLL IN OUT CDR_BASE_OBJ_COLL, PIO_TARGETBASEOBJ IN OUT CDR_BASE_OBJ_TYPE, RENUMBER IN VARCHAR2 );
Parameters
For each Report Set Entry that you want to move, initialize a CDR_BASE_OBJ_TYPE and then
CDR_BASE_OBJ_TYPE. Enter values to identify the Report Set or Report Set Entry into which
you want to move Report Set Entries.
- RENUMBER Enter either TRUE or FALSE. When you move a Report Set Entry, the
API determines whether or not the numbering of the target Report Set or Report Set Entry is
still valid.
If you enter TRUE, the API automatically renumbers the target to make its numbering valid.
If you enter FALSE, the copy operation fails if it creates invalid numbering.
Use this API to change the order of Report Set Entries within a parent Report Set or Report Set Entry.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.ReorderReportSetEntry
Signature
PROCEDURE REORDERREPORTSETENTRY( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_REORDERCOLL IN OUT CDR_REORDER_OBJ_COLL );
Parameters
PI_REORDERCOLL (Mandatory) Initialize a CDR_REORDER_OBJ_TYPE for each child Report Set Entry in the same parent Report Set or Report Set Entry, including the correct new Position and Entry Number, in the correct new order, and then extend the collection.
The following attributes are required: COMPANY_ID,OBJ_ID,OBJ_VER,OBJECT_VERSION_NUMBER,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER,POSITION,ENTRY_NUMBER,OBJECT_VERSION_NUMBER.
Use this API to determine whether or not the Report Set is currently checked out. The API returns $YESNO$YES if it is checked out and $YESNO$NO if it is not checked out.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.GetRSCheckOutFlagRC
Signature
FUNCTION GETRSCHECKOUTFLAGRC( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, PI_COMPANYID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_OBJID IN CDR_NAMINGS.OBJ_ID%TYPE ) RETURN CDR_NAMINGS.CHECKED_OUT_FLAG_RC%TYPE;
Return
CDR_NAMINGS.CHECKED_OUT_FLAG_RC%TYPE Description varchar, returns '$YESNO$YES' or '$YESNO$NO'
Parameters
- PI_COMPANYID (Mandatory) Enter the COMPANY_ID of the Report Set Entry.
- PI_OBJID (Mandatory) Enter the OBJ_ID of the Report Set Entry.
Use this API to check whether a Report Set's Entries conform to the rules you specify for unique and strict numbering.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.IsValidChildrenRSEntries
Signature
FUNCTION ISVALIDCHILDRENRSENTRIES( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, COMPANYID IN CDR_NAMINGS.COMPANY_ID%TYPE, OBJID IN CDR_NAMINGS.OBJ_ID%TYPE, OBJVER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE, UNIQUEFLAG IN CDR_RS_ENTRIES.UNIQUE_NUMBERING_FLAG_RC%TYPE, STRICTFLAG IN CDR_RS_ENTRIES.STRICT_NUMBERING_FLAG_RC%TYPE ) RETURN VARCHAR2;
Return
Type VARCHAR2
Description varchar2 true or false
Parameters
- COMPANYID Enter the Company ID of the Report Set.
- OBJID Enter the object ID of the Report Set.
- OBJVER Enter the object version of the Report Set.
- UNIQUEFLAG Enter Y to validate the Report Set's numbering for uniqueness. Enter N to allow non-unique Report Set Entry numbers within the Report Set.
- STRICTFLAG Enter Y to validate the Report Set for strictly sequential numbering, with no gaps allowed. Enter N to allow gaps in numbering between sibling Report Set Entries within the Report Set.
Use this API to determine whether or not a Report Set or Report Set Entry contains child Report Set Entries.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.HasChildren
Signature
FUNCTION HASCHILDREN( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, PI_COMPANYID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_NS_OBJID IN CDR_NAMINGS.OBJ_ID%TYPE, PI_NS_OBJVER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE ) RETURN VARCHAR2;
Return
Type VARCHAR2
Description varchar Y or N depending on if the RS has children or not.
Parameters
- PI_COMPANYID (Mandatory) Enter the COMPANY_ID of the Report Set or Report Set Entry.
- PI_NS_OBJID (Mandatory) Enter the OBJ_ID of the Report Set or Report Set Entry.
- PI_NS_OBJVER (Mandatory) Enter the OBJ_VER of the Report Set or Report Set Entry.
Use this API to determine whether or not you (the current user) have permission to modify a particular Report Set Entry. This API takes into consideration the validation status of the Report Set or RSE and whether you have the RS Modify privilege, the RS Modify QC privilege, the RS Modify Production privilege, or none of these privileges.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.HasReportModPermission
Signature
FUNCTION HASREPORTMODPERMISSION( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, PI_COMPANYID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_OBJID IN CDR_NAMINGS.OBJ_ID%TYPE, PI_OBJVER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE, RAISEEXECPTION IN VARCHAR2 := 'N' ) RETURN VARCHAR2;
Return
Type VARCHAR2
Parameters
- PI_OBJVER (Mandatory) Enter the OBJ_VER of the Report Set Entry.
- RAISEEXECPTION If you enter Y here and you do not have the required
privileges to modify the Report Set Entry, the API raises an exception.
If you enter N, the API tests for different conditions.
If you do not have the required privileges to modify the RSE, the API returns N irrespective of the RSE's validation status.
If the RSE's validation status is Development, the API returns Y if you have modify privileges on the RSE and N if you do not.
If the RSE's validation status is QC or Production, the API checks if you have Modify QC or Modify Production, respectively.
If you do not have the privilege required to modify an RSE of the current validation status, the API returns VIRTUAL_LOCK.
However, you may be able to modify other RSEs in the same Report Set.
Use this API to remove one or more Report Set Entries from a Report Set or parent Report Set Entry.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.RemoveObjectsFromRSEntries
Signature
PROCEDURE REMOVEOBJECTSFROMRSENTRIES( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_CDRBASEOBJCOLL IN OUT CDR_BASE_OBJ_COLL, RENUMBER IN VARCHAR2 );
Parameters
For each Report Set Entry that you want to copy, initialize a CDR_BASE_OBJ_TYPE and then
- RENUMBER Enter either TRUE or FALSE. When you remove a Report Set Entry, the API determines whether or not the numbering of the parent Report Set or Report Set Entry is still valid. If you enter TRUE, the API automatically renumbers the target to make its numbering valid. If you enter FALSE, the Remove operation fails if it creates invalid numbering.
Use this API to remove a Report Set Entry from a Report Set. If the removal of the RSE causes invalid numbering in the remaining RSEs, the API generates an error.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.RemoveReportSetEntry
Signature
PROCEDURE REMOVEREPORTSETENTRY( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_CDRBASEOBJ IN OUT CDR_BASE_OBJ_TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PI_CDRBASEOBJ (Mandatory) This is a parameter of table type CDR_BASE_OBJ_TYPE. Enter values to identify the Report Set Entry from which you want to unassign the Planned Output.
The following attributes are required: COMPANY_ID, OBJ_ID AND OBJ_VER,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER, OBJECT_VERSION_NUMBER.
Use this API to get the name of the Report Set you specify.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.GetReportSetName
Signature
FUNCTION GETREPORTSETNAME( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, PI_COMPANYID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_OBJID IN CDR_NAMINGS.OBJ_ID%TYPE ) RETURN CDR_NAMINGS.NAME%TYPE;
Return
Type CDR_NAMINGS.NAME%TYPE
Description varchar Name of the RS
Parameters
- PI_COMPANYID (Mandatory) Enter the Company ID of the Report Set.
- PI_OBJID (Mandatory) Enter the Object ID of the Report Set.
Get a Title
Use this API to get the full title of a Report Set or Report Set Entry. If you do not specify a version, the API returns the value for the most recent version.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.GetTitle
Signature
FUNCTION GETTITLE( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, PI_COMPANYID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_OBJID IN CDR_NAMINGS.OBJ_ID%TYPE, PI_OBJVER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE ) RETURN VARCHAR2;
Return
Type VARCHAR2
Parameters
Use this API to get the chapter number of a Report Set Entry.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.GetChapterNumber
Signature
FUNCTION GETCHAPTERNUMBER( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, PI_COMPANYID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_OBJID IN CDR_NAMINGS.OBJ_ID%TYPE, PI_OBJVER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE ) RETURN VARCHAR2;
Return
Type VARCHAR2
Description varchar returns the chapter number of the reportset entry
Parameters
Get a Parent Number
Use this API to get the chapter number of the parent Report Set Entry of the RSE you specify. If the parent is the Report Set itself, the API returns Null.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.GetParentNumber
Signature
FUNCTION GETPARENTNUMBER( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, PI_COMPANYID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_OBJID IN CDR_NAMINGS.OBJ_ID%TYPE, PI_OBJVER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE ) RETURN VARCHAR2;
Return
Type VARCHAR2
Description varchar returns the parent number of the object
Parameters
Use this API to get a list of the full titles and version numbers of all the RSEs in a direct path to a particular Report Set Entry, from the top of the Report Set down to the Report Set Entry you specify.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.TopDownListOfRSetitles
Signature
FUNCTION TOPDOWNLISTOFRSETITLES( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, PI_NCOMPANYID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_NRSEOBJID IN CDR_NAMINGS.OBJ_ID%TYPE, PI_NRSEOBJVER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE, PI_NRSOBJID IN CDR_NAMINGS.OBJ_ID%TYPE, PI_NRSOBJVER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE ) RETURN CDR_VALS_COLL;
Return
Type CDR_VALS_COLL
Description CDR_VALS_COLL returns the list of RSE titles top down
Parameters
- PI_NCOMPANYID (Mandatory) Enter the COMPANY_ID of the Report Set Entry.
- PI_NCOMPANYID (Mandatory) Enter the OBJ_ID of the Report Set Entry.
- PI_NRSEOBJID (Mandatory) Enter the OBJ_ID of the Report Set Entry.
- PI_NRSOBJID (Mandatory) Enter the OBJ_ID of the parent Report Set.
- PI_NRSOBJVER (Mandatory) Enter the OBJ_VER of the Report Set Entry.
Use this API to get a list of the full titles of all the RSEs in a Report Set from the top down.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.TopDownListOfRSeTitles
Signature
FUNCTION TOPDOWNLISTOFRSETITLES( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, PI_COMPANYID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_OBJID IN CDR_NAMINGS.OBJ_ID%TYPE, PI_OBJVER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE ) RETURN CDR_VALS_COLL;
Return
Type CDR_VALS_COLL
Parameters
Use this API to retrieve attribute values for a Report Set Entry that are derived from its parent Report Set or Report Set Entry, including those that are dynamically derived and those that are derived only when the child Report Set Entry is initially created.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.GetDerivedAttrValuesFromParent
Signature
PROCEDURE GETDERIVEDATTRVALUESFROMPARENT( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_COMPANY_ID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_NAMESPACE_OBJ_ID IN CDR_NAMINGS.NAMESPACE_OBJ_ID%TYPE, PI_NAMESPACE_OBJ_VER IN CDR_NAMING_VERSIONS.NAMESPACE_START_OBJ_VER%TYPE, PI_CDRRSENTRY IN OUT CDR_RS_ENTRY_OBJ_TYPE, PI_PARENT_NUMBER OUT VARCHAR2 );
Parameters
- PI_COMPANY_ID (Mandatory) Enter the COMPANY_ID of the parent Report Set or Report Set Entry.
- PI_NAMESPACE_OBJ_ID (Mandatory) Enter the OBJ_ID of the Report Set or Report Set Entry.
- PI_NAMESPACE_OBJ_VER (Mandatory) Enter the OBJ_VER of the parent Report Set or Report Set Entry.
- PI_CDRRSENTRY (Mandatory) This is a parameter of table type CDR_RS_ENTRY_OBJ_TYPE that contains attributes specific to Report Set Entries. Enter values to identify the Report Set Entry for which you want to retrieve inherited attributes.
- PI_PARENT_NUMBER This output parameter returns the chapter number of the
If the parent is the Report Set itself, the parameter returns NULL.
Use this API to get the number of the lowest numbered child Report Set Entry in the Report Set or RSE you specify.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.GetMinEntryNumber
Signature
FUNCTION GETMINENTRYNUMBER( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, PI_COMPANY_ID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_NAMESPACE_OBJ_ID IN CDR_NAMINGS.NAMESPACE_OBJ_ID%TYPE, PI_NAMESPACE_OBJ_VER IN CDR_NAMING_VERSIONS.NAMESPACE_START_OBJ_VER%TYPE ) RETURN CDR_RS_ENTRIES.ENTRY_NUMBER%TYPE;
Return
Type CDR_RS_ENTRIES.ENTRY_NUMBER%TYPE
Parameters
- PI_COMPANY_ID (Mandatory) Enter the COMPANY_ID of the Report Set or Report Set Entry.
- PI_NAMESPACE_OBJ_ID (Mandatory) Enter the OBJ_ID of the Report Set.
- PI_NAMESPACE_OBJ_VER (Mandatory) Enter the OBJ_VER of the Report Set.
Use this API to get the number of the highest numbered child Report Set Entry in the Report Set or RSE you specify.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.GetMaxEntryNumber
Signature
FUNCTION GETMAXENTRYNUMBER( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, PI_COMPANY_ID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_NAMESPACE_OBJ_ID IN CDR_NAMINGS.NAMESPACE_OBJ_ID%TYPE, PI_NAMESPACE_OBJ_VER IN CDR_NAMING_VERSIONS.NAMESPACE_START_OBJ_VER%TYPE ) RETURN CDR_RS_ENTRIES.ENTRY_NUMBER%TYPE;
Return
Parameters
- PI_COMPANY_ID (Mandatory) Enter the COMPANY_ID of the Report Set.
Create a Narrative
Use this API to create a narrative for an existing Report Set Entry.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.CreateNarrative
Signature
PROCEDURE CREATENARRATIVE( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_CDRRSENARRATIVE IN OUT CDR_RSE_NARRATIVE_OBJ_TYPE, PIO_BASEOBJECT IN OUT CDR_BASE_OBJ_TYPE );
Parameters
- PI_CDRRSENARRATIVE (Mandatory) This is a parameter of type
CDR_RSE_NARRATIVE_OBJ_TYPE that contains details of the narrative to be added.
The following attributes are required: COMPANY_ID, NARRATIVE_MODE(PRE/POST),NARRATIVE_TEXT,NARRATIVE_TYPE(TEXT or TEXT/PLAIN),FILE_NAME.
- PIO_BASEOBJECT (Mandatory) This is a parameter of table type
CDR_BASE_OBJ_TYPE. Enter values to identify the Report Set Entry to which you want to create
a Narrative.
Update a Narrative
Use this API to update a narrative for an existing Report Set Entry.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.UpdateNarrative
Signature
PROCEDURE UPDATENARRATIVE( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_CDRRSENARRATIVE IN OUT CDR_RSE_NARRATIVE_OBJ_TYPE, PIO_BASEOBJECT IN OUT CDR_BASE_OBJ_TYPE );
Parameters
CDR_RSE_NARRATIVE_OBJ_TYPE that contains details of the narrative to be updated.
update a narrative.
Delete a Narrative
Use this API to delete a narrative for an existing Report Set Entry.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.DeleteNarrative
Signature
PROCEDURE DELETENARRATIVE( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_CDRRSENARRATIVE IN OUT CDR_RSE_NARRATIVE_OBJ_TYPE, PIO_BASEOBJECT IN OUT CDR_BASE_OBJ_TYPE );
Parameters
CDR_RSE_NARRATIVE_OBJ_TYPE that contains details of the narrative to be deleted.
The following attributes are required: COMPANY_ID, NARRATIVE_MODE(PRE/POST).
delete a narrative.
Use this API to determine whether copying a given set of Report Set Entries into another Report Set or Report Set Entry would result in invalid numbering in the target RS or RSE.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.ValidateCopyRSEList
Signature
FUNCTION VALIDATECOPYRSELIST( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, PIO_CDRBASEOBJCOLL IN CDR_BASE_OBJ_COLL, PIO_TARGETBASEOBJ IN CDR_BASE_OBJ_TYPE ) RETURN VARCHAR2;
Return
Type VARCHAR2
Description varchar2 success or failure
Parameters
you want to copy Report Set Entries.
Use this API to determine whether moving a given set of Report Set Entries into another Report Set or Report Set Entry would result in invalid numbering in the target RS or RSE. The API returns TRUE if the numbering will remain valid or FALSE if the numbering will become invalid.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.ValidateMoveIntoRSEList
Signature
FUNCTION VALIDATEMOVEINTORSELIST( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, PIO_CDRBASEOBJCOLL IN CDR_BASE_OBJ_COLL, PIO_TARGETBASEOBJ IN CDR_BASE_OBJ_TYPE ) RETURN VARCHAR2;
Return
Type VARCHAR2
Parameters
Use this API to determine whether moving a given set of Report Set Entries out of its parent Report Set or RSE would result in invalid numbering in the parent RS or RSE.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.ValidateMoveFromRSEList
Signature
FUNCTION VALIDATEMOVEFROMRSELIST( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, PIO_CDRBASEOBJCOLL IN CDR_BASE_OBJ_COLL ) RETURN VARCHAR2;
Return
Type VARCHAR2
Parameters
PIO_CDRBASEOBJCOLL (Mandatory) This is a collection of CDR_BASE_OBJ_TYPEs. For each Report Set Entry that you want to copy, initialize a CDR_BASE_OBJ_TYPE and then extend the collection.
Use this API to determine whether removing a given set of Report Set Entries would result in invalid numbering in the parent RS or RSE.
Name
CDR_PUB_RS_REPORT_SET_ENTRYCDR_PUB_RS_REPORT_SET_ENTRY.ValidateRemoveRSEList
Signature
FUNCTION VALIDATEREMOVERSELIST( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, PIO_CDRBASEOBJCOLL IN CDR_BASE_OBJ_COLL ) RETURN VARCHAR2;
Return
Type VARCHAR2
Parameters
Use this API to determine whether reordering a collection of Report Set Entries would result in invalid numbering in the parent RS or RSE. To actually reorder the RSEs use ReorderReportSetEntry.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.ValidateReorderList
Signature
FUNCTION VALIDATEREORDERLIST( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, REORDERCOLL IN CDR_REORDER_OBJ_COLL ) RETURN VARCHAR2
Return
Type VARCHAR2
Parameters
REORDERCOLL Initialize a CDR_REORDER_OBJ_TYPE for each child Report Set Entry in the same parent Report Set or Report Set Entry, including the correct new position and Entry Number, in the correct new order, and then extend the collection. All the attributes are mandatory.
Use this API to unassign a Planned Output from a Report Set Entry.
Name
CDR_PUB_RS_REPORT_SET_ENTRY.RemovePOAssignment
Signature
PROCEDURE REMOVEPOASSIGNMENT( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_CDRBASEOBJ IN CDR_BASE_OBJ_TYPE );
Parameters
This is a public interface for all functions related to Report Sets.
- Check Out a Report Set
- Undo a Report Set Checkout
- Copy Objects Into a Report Set
- Get a Summary Output Validation Status
- Move Objects into a Report Set
- Remove Objects from a Report Set
- Check In a Report Set
- Remove a Report Set Definition
Create a Report Set
Use this API to create a new Report Set definition only, a new instance of an existing Report Set definition, or a new definition and an instance of it.
Name
CDR_PUB_RS_REPORT_SET.CreateReportSet
Signature
PROCEDURE CREATEREPORTSET( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE, PI_REPORTSET IN CDR_REPORT_SET_OBJ_TYPE, PI_CREATEOBJECT IN VARCHAR2, PI_INSTANCE_SUBTYPE_ID IN CDR_NAMINGS.OBJECT_SUBTYPE_ID%TYPE, PI_DEFCLASSIFICATIONCOLL IN CDR_CLASSIFICATIONS_COLL, PI_INSTCLASSIFICATIONCOLL IN CDR_CLASSIFICATIONS_COLL );
Parameters
- PI_REPORTSET (Mandatory) This is a parameter of table type
CDR_REPORT_SET_OBJ_TYPE.
Enter values for the Report Set definition you want to create.
If you are creating an instance of an existing definition, enter values to identify the definition you want to create an instance of. The following attributes are required: UNIQUE_NUMBERING_FLAG_RC,STRICT_NUMBERING_FLAG_RC.
- PI_CREATEOBJECT (Mandatory) Enter DEFN to create a definition only; INST to create a instance of an existing definition; or BOTH to create a new definition and an instance of it.
- PI_INSTANCE_SUBTYPE_ID (Optional) If you are creating a new instance, enter
the ID for the subtype you want to give the instance.
If you are creating a definition only, do not enter a value for this parameter.
- PI_DEFCLASSIFICATIONCOLL (Optional) By default the new definition is
classified according to the subtype you assigned it in the CDR_NAMING_VERSION_OBJ_TYPE.
If you want to override the default classifications for one or more classification levels, use this parameter. This is a collection of CDR_CLA_OBJ_TYPEs, which have 5 attributes, including CLA_LEVEL_ID and CLASSIFICATION_ID.
If you want the definition to inherit its classifications for a particular level from its parent, enter the classification level ID and, for the CLASSIFICATION_ID, enter 0 (zero).
If you want to explicitly assign one or more terms for a particular level, initialize a CDR_CLA_OBJ_TYPE for each term, entering the classification level ID and, for the CLASSIFICATION_ID, the term ID. The PAR_ attributes are not relevant to Report Sets. Do not enter any values for them. If you are not creating a new definition, do not enter values here.
- PI_INSTCLASSIFICATIONCOLL (Optional) By default the new instance is
classified according to the subtype you assigned it in the PI_INSTANCE_SUBTYPE_ID.
If you want the instance to inherit its classifications for a particular level from its parent Work Area, enter the classification level ID and, for the CLASSIFICATION_ID, enter 0 (zero).
If you want to explicitly assign one or more terms for a particular level, initialize a CDR_CLA_OBJ_TYPE for each term, entering the classification level ID and, for the CLASSIFICATION_ID, the term ID. The PAR_ attributes are not relevant to Report Sets. Do not enter any values for them. If you are not creating a new instance, do not enter values here.
Parent topic: Create and Modify Report Sets
Use this API to check out a Report Set definition.
Name
CDR_PUB_RS_REPORT_SET.CheckOutReportSet
Signature
PROCEDURE CHECKOUTREPORTSET( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_CDRREPORTSET IN OUT CDR_BASE_OBJ_TYPE, PI_COMMENT IN VARCHAR2, PI_ISINSTONLY IN VARCHAR2, PI_OPTYPE IN VARCHAR2 );
Parameters
- PI_CDRREPORTSET (Mandatory) This is a parameter of table type
CDR_BASE_OBJ_TYPE. Enter values to identify the Report Set definition that you want to
check in.
- PI_COMMENT (Optional) Enter the reason you are checking in the Report Set definition.
- PI_ISINSTONLY (Mandatory) Enter $YESNO$NO
- PI_OPTYPE (Mandatory) Set to NULL.
Use this API to undo the checkout of a Report Set definition, discarding any changes that have been made.
Name
CDR_PUB_RS_REPORT_SET.UncheckOutReportSetDef
Signature
PROCEDURE UNCHECKOUTREPORTSETDEF( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_CDRREPORTSET IN OUT CDR_BASE_OBJ_TYPE );
Parameters
PIO_CDRREPORTSET (Mandatory) This is a collection of CDR_BASE_OBJ_TYPEs. For each Report Set that you want to remove, initialize a CDR_BASE_OBJ_TYPE and then extend the collection.
Use this API to copy one or more Report Set Entries and Program instances into a Report Set definition. You may specify a Report Set instance into which you want to copy the Report Set Entries. In that case, the system copies the Report Set Entries into the Report Set definition that the Report Set instance references and the Report Set instance you specify is upgraded to point to the new version of the Report Set definition.
Name
CDR_PUB_RS_REPORT_SET.CopyObjectsIntoReportSet
Signature
PROCEDURE COPYOBJECTSINTOREPORTSET( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_CDRBASEOBJECTCOLL IN OUT CDR_BASE_OBJ_COLL, PI_CDRTARGETCONTAINEROBJECT IN OUT CDR_BASE_OBJ_TYPE, PI_CHECKINFLAG IN VARCHAR2, PI_COPYPRGASSGNMT IN VARCHAR2 );
Parameters
- PI_CDRBASEOBJECTCOLL (Mandatory) This is a collection of cdr_base_obj_type
that is used to describe the Report Set Entries you want to copy.
Enter values for attributes COMPANY_ID, OBJ_ID, OBJ_VER, NAMESPACE_OBJ_ID, NAMESPACE_OBJ_VER, AND OBJECT_VERSION_NUMBER for each RSE you want to copy. All children, grandchildren, etc. RSEs of the RSEs you specify are included in the Copy operation.
Enter COMPANY_ID, OBJ_ID AND OBJ_VER,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER, OBJECT_VERSION_NUMBER for each RSE
- PI_CDRTARGETCONTAINEROBJECT (Mandatory) This is a parameter of table type
CDR_BASE_OBJ_TYPE. Enter values to identify the Report Set into which you want to copy the
specified Report Set Entries.
The following attributes are required: COMPANY_ID, OBJ_ID AND OBJ_VER,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER, OBJECT_VERSION_NUMBER of target Report Set Definition.
- PI_CHECKINFLAG (Mandatory) Enter 'Y' so that the copied Report Set Entries are appropriately numbered in their new location.
- PI_COPYPRGASSGNMT (Mandatory) Enter 'Y' to copy any Program instances
currently assigned to the Report Set Entries to be copied, with their Planned Output
Enter 'N' to avoid copying these Program instances. In this case, all Planned Output assignments are lost.
Use this API to calculate the summary output validation status for the entire Report Set hierarchy in the context of a Report Set instance.
Name
CDR_PUB_RS_REPORT_SET.GetSOVSforRSHierarchy
Signature
FUNCTION GETSOVSFORRSHIERARCHY( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_COMPID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_OBJID IN CDR_NAMINGS.OBJ_ID%TYPE, PI_OBJVER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE, PI_RSIOBJID IN CDR_NAMINGS.OBJ_ID%TYPE, PI_RSIOBJVER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE ) RETURN CDR_SOVS_OBJ_COLL;
Return
Type CDR_SOVS_OBJ_COLL
Parameters
- PI_COMPID (Mandatory) Enter the COMPANY_ID of the Column or Table Descriptor.
- PI_OBJID (Mandatory) Enter the OBJ_ID of the Column or Table Descriptor.
- PI_OBJVER (Mandatory) Enter the OBJ_VER of the Column or Table Descriptor.
- PI_RSIOBJID (Mandatory) Enter the object ID of the Report Set instance.
- PI_RSIOBJVER (Mandatory) Enter the object version of the Report Set instance.
Modify a Report Set
Use this API to modify a Report Set definition or instance. You can modify the name and description. If you are modifying an instance object, you can also change the 3 REF attribute values to select a different source definition.
To modify a definition, you must first check it out.Name
CDR_PUB_RS_REPORT_SET.ModifyReportSetDetails
Signature
PROCEDURE MODIFYREPORTSETDETAILS( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_CDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE, PI_REPORTSET IN CDR_REPORT_SET_OBJ_TYPE );
Parameters
- PIO_CDRNAMING (Mandatory) This is a parameter of table type
Enter values to identify the Report Set and enter new values for the attributes you want to modify. You can change the name or description for either a definition or instance.
For an instance, you can also change to a different underlying source definition by entering values for the new definition in the three REF attributes. All attributes are required.
Use separate APIs for modifying the validation status and the version label: CDR_PUB_VL_VALIDATION.UPDATE VAL STATUS and CDR_PUB_DF_NAMING.UPDATEVERSIONLABEL. - PI_REPORTSET (Mandatory) This is a parameter of table type
CDR_REPORT_SET_OBJ_TYPE that contains Report Set attributes.
Enter values to identify the Report Set definition or instance that you want to modify and enter new values for the attributes you want to modify. You can change the TITLE, the UNIQUE_NUMBERING_FLAG_RC, and the STRICT_NUMBERING_FLAG_RC. All attributes are required.
Use this API to move Program instances and Report Set Entries into a Report Set definition.
Name
CDR_PUB_RS_REPORT_SET.MoveObjectsIntoReportSet
Signature
PROCEDURE MOVEOBJECTSINTOREPORTSET( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_CDRBASEOBJECTCOLL IN OUT CDR_BASE_OBJ_COLL, PI_CDRTARGETCONTAINEROBJECT IN OUT CDR_BASE_OBJ_TYPE );
Parameters
Use this API to remove one or more objects from a Report Set.
Name
CDR_PUB_RS_REPORT_SET.RemoveObjectsFromReportSet
Signature
PROCEDURE REMOVEOBJECTSFROMREPORTSET( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_CDRBASEOBJECTCOLL IN OUT CDR_BASE_OBJ_COLL );
Parameters
PI_CDRBASEOBJECTCOLL (Mandatory) This is a collection of cdr_base_obj_type that is used to describe the Report Set Entries you want to copy.
Use this API to check in a Report Set definition.
Name
CDR_PUB_RS_REPORT_SET.CheckInReportSetDef
Signature
PROCEDURE CHECKINREPORTSETDEF( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_CDRREPORTSET IN OUT CDR_BASE_OBJ_TYPE, PI_COMMENT IN VARCHAR2 );
Parameters
check in.
Use this API to remove a Report Set definition or instance.
Name
CDR_PUB_RS_REPORT_SET.RemoveReportSet
Signature
PROCEDURE REMOVEREPORTSET( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_CDRREPORTSET IN OUT CDR_BASE_OBJ_TYPE );
Parameters
Remove a Report Set
Name
CDR_PUB_RS_REPORT_SET.RemoveReportSets
Signature
PROCEDURE REMOVEREPORTSETS( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_CDRBASEOBJCOLL IN OUT CDR_BASE_OBJ_COLL );
Parameters
This is a public interface used to create, modify and remove OTD files, which are contained by Overlay Template Definitions (OTDs) and used in Report Sets.
- Create an Overlay Template Definition
- Modify an Overlay Template Definition File Definition
- Get an Overlay Template Definition File as a BLOB
- Remove an Overlay Template Definition File Definition
Use this API to create an OTD File definition after you have created an Overlay Template Definition (OTD). Use CDR_PUB_RS_OVERLAY_TEMPLATE.CopyObjectsIntoOTD to assign this OTD File definition to an OTD.
Name
CDR_PUB_RS_OTD_FILE.CreateOTDFile
Signature
PROCEDURE CREATEOTDFILE( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_OTDF_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE, PI_CDROTDFILEOBJTYPE IN OUT CDR_OTDF_OBJ_TYPE, PI_LOBMODE IN VARCHAR := NULL );
Parameters
- PIO_OTDF_SOURCECDRNAMING (Mandatory) This is a parameter of table type
CDR_NAMING_VERSION_OBJ_TYPE. Enter values for the OTD File that you are creating, using
the Namespace attributes to identify the parent Overlay Template Definition.
For OBJECT_TYPE_RC enter $OBJTYPES$OVERLAYTEMPLATEFILE. The following attributes are required: COMPANY_ID,NAME,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER.
- PI_CDROTDFILEOBJTYPE (Mandatory) This is a parameter of table type
CDR_OTDF_OBJ_TYPE that contains object attributes specific to Overlay Template Definition
Files. Enter values for the OTD File that you are creating.
The following attributes are required: OTDF_TYPE_RC,OTDF_PGNO_FLAG,OTDF_ORIENTATION_RC,OTDF_PAPERSIZE,OTDF_LANGUAGE_RC,OTDF_ROTATION,OTDF_FILENAME,OTDF_BLOB.
- PI_LOBMODE (Optional) Enter 'IN_DIRECT'. No other value is supported except Null.
Parent topic: Create and Modify Overlay Template Definitions
Use this API to modify an OTD File definition.
Name
CDR_PUB_RS_OTD_FILE.ModifyOTDFile
Signature
PROCEDURE MODIFYOTDFILE( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_OTDF_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE, PI_CDROTDFILEOBJTYPE IN OUT CDR_OTDF_OBJ_TYPE, PI_LOBMODE IN VARCHAR := NULL );
Parameters
- PIO_OTDF_SOURCECDRNAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the OTD File that you are modifying and enter new values for attributes you want to change. You can change the name and description. All attributes are required.
- PI_CDROTDFILEOBJTYPE (Mandatory) This is a parameter of table type CDR_OTDF_OBJ_TYPE that contains object attributes specific to Overlay Template Definition Files. Enter values to identify the OTD File that you are modifying and enter new values for attributes you want to change. You can change values for Page Number, Orientation, Paper Size, Rotation, or File Name. All attributes are required.
Use this API to upload the RTF file.
Name
CDR_PUB_RS_OTD_FILE.GetOTDBlob
Signature
FUNCTION GETOTDBLOB( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, COMPANYID IN CDR_NAMINGS.COMPANY_ID%TYPE, OBJID IN CDR_NAMINGS.OBJ_ID%TYPE, OBJVER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE ) RETURN BLOB;
Return
Type BLOB
Parameters
- COMPANYID (Mandatory) Enter the Company ID of the OTD File definition.
- OBJID (Mandatory) Enter the Object ID of the OTD File definition.
- OBJVER (Mandatory) Enter the Object version of the OTD File definition.
Use this API to remove one or more OTD File definitions from an OTD.
Name
CDR_PUB_RS_OTD_FILE.RemoveOTDFile
Signature
PROCEDURE REMOVEOTDFILE( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_CDRBASEOBJCOLL IN OUT CDR_BASE_OBJ_COLL );
Parameters
PIO_CDRBASEOBJCOLL (Mandatory) This is a collection of CDR_BASE_OBJ_TYPEs. For each OTD File definition that you want to remove, initialize a CDR_BASE_OBJ_TYPE and then extend the collection.
This package is used to create, check in, check out, and modify the Report Set Entry. templates.
- Check Out an Overlay Template
- Undo an Overlay Template Checkout
- Copy Objects Into an Overlay Template
- Check In an Overlay Template
Use this API to create an Overlay Template definition (OTD).
Name
CDR_PUB_RS_OVERLAY_TEMPLATE.CreateOverlayTemplate
Signature
PROCEDURE CREATEOVERLAYTEMPLATE( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_OTD_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE, PI_CDROTDOBJTYPE IN OUT CDR_OTD_OBJ_TYPE, PO_DEFCLASSIFICATIONCOLL IN CDR_CLASSIFICATIONS_COLL );
Parameters
- PIO_OTD_SOURCECDRNAMING (Mandatory) This is a parameter of table type
CDR_NAMING_VERSION_OBJ_TYPE. Enter values for the Overlay Template Definition (OTD) that
you are creating.
For OBJECT_TYPE_RC enter $OBJTYPES$OVERLAYTEMPLATE. The following attributes are required: COMPANY_ID,NAME,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER.
- PI_CDROTDOBJTYPE (Mandatory) This is a parameter of table type
CDR_OTD_OBJ_TYPE that contains object attributes specific to Overlay Templates. Enter
values for the Overlay Template that you are creating.
The following attributes are required: OTD_DEFAULT_PAPERSIZE,OTD_DEFAULT_LANGUAGE_RC.
- PO_DEFCLASSIFICATIONCOLL (Optional) By default the new definition is
If you want to explicitly assign one or more terms for a particular level, initialize a CDR_CLA_OBJ_TYPE for each term, entering the classification level ID and, for the CLASSIFICATION_ID, the term ID. The PAR_ attributes are not relevant to OTDs. Do not enter any values for them.
Parent topic: Report Set Overlay Template
Use this API to check out an Overlay Template Definition (OTD).
Name
CDR_PUB_RS_OVERLAY_TEMPLATE.CheckOutOverlayTemplate
Signature
PROCEDURE CHECKOUTOVERLAYTEMPLATE( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_BASEOBJECT IN OUT CDR_BASE_OBJ_TYPE, PI_COMMENT IN VARCHAR2, PI_ISINSTONLY IN VARCHAR2 );
Parameters
CDR_BASE_OBJ_TYPE. Enter values to identify the OTD that you want to check in.
- PI_COMMENT (Optional) Enter the reason you are checking in the OTD.
- PI_ISINSTONLY (Mandatory) Enter $YESNO$NO.
Use this API to undo the checkout of an Overlay Template Definition (OTD).
Name
CDR_PUB_RS_OVERLAY_TEMPLATE.UndoCheckOutOverlayTemplate
Signature
PROCEDURE UNDOCHECKOUTOVERLAYTEMPLATE( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_BASEOBJECT IN OUT CDR_BASE_OBJ_TYPE );
Parameters
PIO_BASEOBJECT (Mandatory) This is a parameter of table type CDR_BASE_OBJ_TYPE. Enter values to identify the OTD whose checkout you want to undo.
Use this API to copy OTD File definitions into an Overlay Template Definition.
Name
Signature
PROCEDURE COPYOBJECTSINTOOTD( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_CDRBASEOBJCOLL IN CDR_BASE_OBJ_COLL, PI_CDRTARGETCONTAINEROBJECT IN CDR_BASE_OBJ_TYPE );
Parameters
- PI_CDRBASEOBJCOLL (Mandatory) This is a collection of CDR_BASE_OBJ_TYPEs.
For each OTD file definition that you want to copy into an OTD, initialize a
- PI_CDRTARGETCONTAINEROBJECT (Mandatory) This is a parameter of table type CDR_BASE_OBJ_TYPE. Enter values to identify the OTD into which you want to copy OTD File definitions. The following attributes are required: COMPANY_ID,OBJ_ID,OBJ_VER,OBJECT_VERSION_NUMBER,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER.
Use this API to modify an Overlay Template Definition (OTD).
Name
CDR_PUB_RS_OVERLAY_TEMPLATE.ModifyOverlayTemplate
Signature
PROCEDURE MODIFYOVERLAYTEMPLATE( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_OTD_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE, PI_CDROTDOBJTYPE IN OUT CDR_OTD_OBJ_TYPE );
Parameters
- PIO_OTD_SOURCECDRNAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the Overlay Template Definition (OTD) that you are modifying, and enter new values for the attributes you want to modify. You can change the name and description. All attributes are required.
PI_CDROTDOBJTYPE Object Type of Overlay Template Definition
Use this API to check in an Overlay Template Definition.
Name
CDR_PUB_RS_OVERLAY_TEMPLATE.CheckInOverlayTemplate
Signature
PROCEDURE CHECKINOVERLAYTEMPLATE( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_BASEOBJECT IN OUT CDR_BASE_OBJ_TYPE, PI_COMMENT IN VARCHAR2 );
Parameters
Use this API to remove one or more Overlay Template Definitions (OTDs).
Name
CDR_PUB_RS_OVERLAY_TEMPLATE.RemoveOverlayTemplate
Signature
PROCEDURE REMOVEOVERLAYTEMPLATE( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_CDRBASEOBJCOLL IN OUT CDR_BASE_OBJ_COLL );
Parameters
PIO_CDRBASEOBJCOLL (Mandatory) This is a collection of CDR_BASE_OBJ_TYPEs. For each OTD that you want to remove, initialize a CDR_BASE_OBJ_TYPE and then extend the collection.
