16 Work Areas
This is a public interface for Work Area-related operations, including creating, modifying, removing, cloning, checking in and installing Work Areas. It also includes an API to copy instance objects into a Work Area and an API to install a single Program.
Parent topic: Object APIs
Define and Modify Work Areas
- Create a Work Area
- Install a Work Area
- Check In a Work Area
- Modify a Work Area
- Clone a Work Area
- Copy Objects into a Work Area
- Clone an Object
- Remove a Work Area
- Get the Usage Intent RC of a Work Area
- Update a Work Area's Usage Intent
- Install a Program
- Apply or Move a Snapshot Label
- Remove a Snapshot Label from a Work Area
Parent topic: Work Areas
Create a Work Area
Use this API to create a new Work Area.
Name
CDR_PUB_DF_WORKAREA.CreateWorkArea
Signature
PROCEDURE CREATEWORKAREA( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE, PIO_WORKAREAOBJTYPE IN OUT CDR_WORKAREA_OBJ_TYPE, PI_DEFCLASSIFICATIONCOLL IN CDR_CLASSIFICATIONS_COLL );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PIO_WORKAREAOBJTYPE (Mandatory) This is a parameter of table type
CDR_WORKAREA_OBJ_TYPE that contains object attributes specific to Work Areas. Enter values
for the Work Area that you want to create.
The following attributes are required: COMPANY_ID, OBJ_ID, OBJ_VER. For OBJECT_TYPE_RC enter $OBJTYPES$WORKAREA. By default, new Work Areas receive a Usage Intent value of Development.
- PIO_SOURCECDRNAMING (Mandatory) This is a parameter of table type
CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the Work Area that you want to
create.
The following attributes are required: COMPANY_ID,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER,OBJECT_TYPE_RC. FOR OBJECT_TYPE_RC ENTER $OBJTYPES$WORKAREA.
- PI_DEFCLASSIFICATIONCOLL (Optional) By default the new Work Area is
classified according to the subtype you assigned it in the CDR_NAMING_VERSION_OBJ_TYPE.
If you want to override the default classifications for one or more classification levels, use this parameter. This is a collection of CDR_CLA_OBJ_TYPEs, which have 5 attributes, including CLA_LEVEL_ID and CLASSIFICATION_ID. If you want the Work Area to inherit its classifications for a particular level from its parent Application Area, enter the classification level ID and, for the CLASSIFICATION_ID, enter 0 (zero). If you want to explicitly assign one or more terms for a particular level, initialize a CDR_CLA_OBJ_TYPE for each term, entering the classification level ID and, for the CLASSIFICATION_ID, the term ID. The PAR_ attributes are not relevant to Work Areas. Do not enter any values for them.
Parent topic: Define and Modify Work Areas
Install a Work Area
Use this API to install a Work Area and the instance objects in it that you specify. The API first tries to check in the Work Area and all the object instances included in the installation. If any object included in the installation is checked out by another user, the installation fails.
Name
CDR_PUB_DF_WORKAREA.InstallWAController
Signature
PROCEDURE INSTALLWACONTROLLER( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_OWABASENAMING IN OUT CDR_BASE_OBJ_TYPE, PI_VINSTALLMODE IN CDR_INSTALLATIONS.INSTALLATION_MODE_RC%TYPE, PI_VFORCEREGEN IN CDR_INSTALLATIONS.FORCE_REGEN_FLAG_RC%TYPE, PI_VBATCH IN CDR_INSTALLATIONS.BATCH_FLAG_RC%TYPE, PI_VACTION IN CDR_INST_ELEMENTS.INSTALL_ACTION_RC%TYPE, PI_COINSTDETAILS IN CDR_INSTALLATION_DETAILS_COLL );
Parameters
- PIO_OWABASENAMING (Mandatory) This is a parameter of table type CDR_BASE_OBJ_TYPE. Enter values to identify the Work Area that you want to install. The following attributes are required: COMPANY_ID,OBJECT_ID,OBJECT_VER,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER, OBJECT_VERSION_NUMBER.
- PI_VINSTALLMODE (Mandatory) Specify the installation mode you want to use: Enter FULL, UPGRADE, or PARTIAL.
- PI_VFORCEREGEN (Optional) If you selected Upgrade mode, enter $YESNO$YES to force the system to generate new install scripts (and reinstall) all objects, whether or not they have been modified since the last installation of this Work Area. Enter $YESNO$NO to generate install scripts only for objects and object versions that have never been successfully installed.
- PI_VBATCH (Mandatory) Enter $YESNO$YES to perform installation in batch mode. Enter $YESNO$NO to perform installation in interactive mode.
- PI_VACTION (Mandatory) Enter COMPLETE if this is the first time the Work Area is being installed, or if the last installation was successful, or if the last installation failed and you want to continue from the last successfully completed phase. Enter CANCEL if the last installation failed and you want to begin the installation process from the beginning.
- PI_COINSTDETAILS (Mandatory) This is a collection of CDR_INST_DET_OBJ_TYPEs.
For each object in the Work Area that you want to install, initialize a
CDR_INST_DET_OBJ_TYPE and then extend the collection.
The following attributes are required: COMPANY_ID,OBJ_ID,OBJ_VER,OBJECT_VERSION_NUMBER,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER.
For OMIT_FROM_INSTALL_FLAG_RC, enter $YESNO$NO to include the object in the installation, subject to the rules for the installation type (Full, Partial, or Upgrade). If you are performing installation in PARTIAL mode, you must provide a value for each object for INSTALL_ACTION_RC of to indicate if you want to drop and replace or upgrade each object.
Use this API to check in a Work Area and all the object instances it contains.
Name
CDR_PUB_DF_WORKAREA.CheckInWorkArea
Signature
PROCEDURE CHECKINWORKAREA( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_BASENAMING IN OUT CDR_BASE_OBJ_TYPE, PI_COMMENT IN VARCHAR2 );
Parameters
- PIO_BASENAMING (Mandatory) This is a parameter of table type
CDR_BASE_OBJ_TYPE. Enter values to identify the Work Area that you want to check in.
- PI_COMMENT (Optional) Enter the reason you are checking in the Work Area.
Modify a Work Area
Use this API to modify the name and/or description of an existing Work Area. (Use CDR_PUB_DF_WORKAREA.UPDATEUSAGEINTENT to modify a Work Area's Usage Intent attribute.)
Name
CDR_PUB_DF_WORKAREA.ModifyWorkArea
Signature
PROCEDURE MODIFYWORKAREA( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE, PIO_WORKAREAOBJTYPE IN OUT CDR_WORKAREA_OBJ_TYPE );
Parameters
- PIO_SOURCECDRNAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the Work Area that you want to modify and the values you want to change. All attributes are required.
- PIO_WORKAREAOBJTYPE (Mandatory) This is a parameter of table type CDR_WORKAREA_OBJ_TYPE that contains object attributes specific to Work Areas. Enter values to identify the Work Area that you want to modify and enter new values for the attributes you want to modify.
Clone a Work Area
Use this API to clone a Work Area. If you specify another Work Area as the target, this API overwrites that Work Area with the source Work Area. If you specify an Application Area as the target, this API creates a new Work Area identical to the source Work Area in the Application Area you specify.
Name
CDR_PUB_DF_WORKAREA.CloneWorkArea
Signature
PROCEDURE CLONEWORKAREA( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_SOURCEOBJECT IN OUT CDR_BASE_OBJ_TYPE, PIO_TARGETOBJECT IN OUT CDR_BASE_OBJ_TYPE, PI_VLABEL IN CDR_WORKAREAS.LABEL%TYPE, PI_VUSAGEINTENTRC IN CDR_WORKAREAS.USAGE_INTENT_RC%TYPE );
Parameters
- PIO_SOURCEOBJECT (Mandatory) This is a parameter of table type
CDR_BASE_OBJ_TYPE. Enter values to identify the Work Area that you want to clone.
The following attributes are required: COMPANY_ID, OBJECT_ID, OBJECT_VER, NAMESPACE_OBJ_ID, NAMESPACE_OBJ_VER, OBJECT_VERSION_NUMBER.
- PIO_TARGETOBJECT (Mandatory) This is a parameter of table type
CDR_BASE_OBJ_TYPE. Enter values to identify the Work Area or Application Area to serve as
the target of the clone. If you specify a Work Area, this API overwrites it with the
source Work Area. If you specify an Application Area, this API creates a new Work Area
identical to the source Work Area in the Application Area.
The following attributes are required: COMPANY_ID, OBJ_ID,OBJ_VER, OBJECT_VERSION_NUMBER, NAMESPACE_OBJ_ID, NAMESPACE_OBJ_VER.
- PI_VLABEL (Mandatory) Enter text for the label you want to assign to the source and target Work Areas.
- PI_VUSAGEINTENTRC (Optional) Enter a value for the Usage Intent attribute of the target Work Area. If you do not enter a value, the API assigns the Usage Intent value of the source Work Area to the target Work Area.
Use this API to copy one or more objects into a Work Area.
Name
CDR_PUB_DF_WORKAREA.CopyObjectsIntoWA
Signature
PROCEDURE COPYOBJECTSINTOWA( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_CDRPRREFOBJCOLL IN CDR_PRREF_OBJ_COLL, PI_CDRTARGETCONTAINEROBJECT IN OUT CDR_PRREF_OBJ_TYPE, PI_CHECKINFLAG IN VARCHAR, PI_COPYPRGASSGNMT IN VARCHAR );
Parameters
- PI_CDRPRREFOBJCOLL (Mandatory) This is a collection of Prref objects that
contains information about the instance objects you want to copy into the Work Area.
Provide values for the attributes COMPANY_ID, OBJ_ID, OBJ_VER, PRREF_ID, PRREF_VER, NAMESPACE_OBJ_ID, NAMESPACE_OBJ_VER,OBJECT_VERSION_NUMBER for each instance object. The PRREF_ID and PRREF_VER attributes store the hierarchy information for objects.
- PI_CDRTARGETCONTAINEROBJECT (Mandatory) This is a parameter of Prref object
type that describes the target Work Area.
Enter values for the attributes COMPANY_ID, OBJ_ID, OBJ_VER, PRREF_ID, PRREF_VER, NAMESPACE_OBJ_ID, NAMESPACE_OBJ_VER,OBJECT_VERSION_NUMBER.
- PI_CHECKINFLAG (Mandatory) Enter 'Y' for this flag.
- PI_COPYPRGASSGNMT (Optional) This parameter is not applicable.
Clone an Object
Use this API to clone one or more instance objects in a Work Area.
Name
CDR_PUB_DF_WORKAREA.CloneObjects
Signature
PROCEDURE CLONEOBJECTS( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_SRCINSTBASEOBJCOLL IN OUT CDR_BASE_OBJ_COLL, PI_TGTWABASEOBJTYPE IN OUT CDR_BASE_OBJ_TYPE );
Parameters
- PI_SRCINSTBASEOBJCOLL (Mandatory) This is a collection of base objects that
you want to clone in the Work Area.
Enter the attributes COMPANY_ID, OBJ_ID, OBJ_VER, PRREF_ID, PRREF_VER, NAMESPACE_OBJ_ID, NAMESAPCE_OBJ_VER,OBJECT_VERSION_NUMBER for each instance object.
- PI_TGTWABASEOBJTYPE (Mandatory) This is a parameter of base object type that
describes the Work Area.
Enter the Work Area's COMPANY_ID, OBJ_ID, OBJ_VER, NAMESPACE_OBJ_ID, NAMESPACE_OBJ_VER,OBJECT_VERSION_NUMBER.
Remove a Work Area
Use this API to remove a Work Area and all the instance objects it contains.
Name
CDR_PUB_DF_WORKAREA.RemoveWorkArea
Signature
PROCEDURE REMOVEWORKAREA( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE );
Parameters
PIO_SOURCECDRNAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the Work Area that you want to remove. The following attributes are required: COMPANY_ID,OBJ_ID,OBJ_VER,OBJECT_VERSION_NUMBER,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER.
Use this API to retrieve the current value of the Usage Intent attribute for a particular Work Area.
Name
CDR_PUB_DF_WORKAREA.GetUsageIntentRC
Signature
PROCEDURE GETUSAGEINTENTRC( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_COMPANY_ID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_OBJ_ID IN CDR_NAMINGS.OBJ_ID%TYPE, PI_OBJ_VER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE, PO_USAGEINTENT OUT CDR_WORKAREAS.USAGE_INTENT_RC%TYPE );
Parameters
- PI_COMPANY_ID (Mandatory) Enter company ID
- PI_OBJ_ID (Mandatory) Enter the object ID of the Work Area.
- PI_OBJ_VER (Mandatory) Enter the object version (OBJ_VER) of the Work Area.
- PO_USAGEINTENT This output parameter returns the current value of the Work Area's Usage Intent attribute.
Use this API to modify the value of the Usage Intent attribute of a Work Area.
Name
CDR_PUB_DF_WORKAREA.UpdateUsageIntent
Signature
PROCEDURE UPDATEUSAGEINTENT( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE, PIO_WORKAREAOBJTYPE IN OUT CDR_WORKAREA_OBJ_TYPE );
Parameters
CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the Work Area whose Usage Intent
attribute you want to modify.
The following attributes are required: COMPANY_ID,OBJ_ID,OBJ_VER.
CDR_WORKAREA_OBJ_TYPE that contains object attributes specific to Work Areas. For
USAGE_INTENT_RC, enter the new value for the Usage Intent attribute.
The allowed values are: $SYSVALDNSTEPS$DEVELOPMENT, $SYSVALDNSTEPS$PRODUCTION, $SYSVALDNSTEPS$QUALITYCONTROL.
Install a Program
Use this API to install a single Program and the Table instances to which it is mapped. You must install a Program and its source Table instances before you can work on it in an Integrated Development Environment (IDE).
Name
CDR_PUB_DF_WORKAREA.InstallIDEcomponents
Signature
PROCEDURE INSTALLIDECOMPONENTS( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_NCOMPANYID IN NUMBER, PI_NWAOBJID IN NUMBER, PI_NWAOBJVER IN NUMBER, PI_NPRREFID IN NUMBER, PI_NPRREFVER IN NUMBER, PO_VINSTLOGTYPE OUT VARCHAR2, PO_VINSTLOG OUT VARCHAR2 );
Parameters
- PI_NCOMPANYID (Mandatory) Enter your company ID. To get your company ID, use CDR_PUB_DEF_FACTORY_UTILS.GetCompanyId.
- PI_NWAOBJID (Mandatory) Enter the object ID of the Work Area where the Program instance is located.
- PI_NWAOBJVER (Mandatory) Enter the object version (OBJ_VER) of the Work Area.
- PI_NPRREFID (Mandatory) Enter the object ID of the Program instance that you want to install.
- PI_NPRREFVER PrrefVer of the Program Instance to be installed
- PO_VINSTLOGTYPE This output parameter returns one of the following values to indicate whether the installation ended with a status of Warning (G_RET_IDE_INST_WARNING) or Success (G_RET_IDE_INST_INFO).
- PO_VINSTLOG This output parameter returns the installation log file (maximum length 32000 characters).
Use this API to apply a snapshot label to some or all tables and/or views in a Work Area.
Name
CDR_PUB_EXE_SNAPSHOT.SetOrMoveLabel
Signature
PROCEDURE SETORMOVELABEL( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, PI_WA_COMPANY_ID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_WA_OBJ_ID IN CDR_NAMINGS.OBJ_ID%TYPE, PI_WA_OBJ_VER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE, PI_LABEL IN CDR_TAB_REF_LABELS.LABEL%TYPE, PI_FORCE_FLAG IN CDR_SUBMISSIONS.FORCE_EXECUTION_FLAG_RC%TYPE, PI_BLIND_FLAG IN CDR_TABLE_REF_JOBS.BLIND_BREAK_FLAG_RC%TYPE, PI_DATE IN DATE DEFAULT NULL, PI_SRC_TAB_COLL CDR_SRC_TABLE_COLL DEFAULT NULL, PI_WA_TABLES_COLL IN OUT NOCOPY CDR_WA_TABLES_COLL, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters. See Functional Rules below for more information.
- PI_WA_COMPANY_ID (Mandatory) Enter the Company ID.
- PI_WA_OBJ_ID (Mandatory) Enter the Work Area object ID.
- PI_WA_OBJ_VER (Mandatory) Enter the latest object version.
- PI_LABEL (Mandatory) Label text.
- PI_FORCEFLAG (Mandatory)
- If set to $YESNO$YES, the API overwrites the previous snapshot label.
- If set to $YESNO$NO the label is not applied.
- PI_BLIND_FLAG (Mandatory) The Blind Break flag ($YESNO$YES, $YESNO$NO).
- PI_DATE (Optional) If this value is used, the API labels only those tables with latest data loads less than or equal to entered value.
- PI_SCR_TAB_COL (Optional) Naming details of source table(s) of view in given
Work Area and corresponding view naming details (to match value with
CDR_WA_TABLES_COLL).
This parameter is of type CDR_SRC_TABLE_OBJ_TYPE and contains the following naming attributes:
- SRC_TI_COMPANY_ID NUMBER(6) Enter the Table or view Company ID.
- SRC_TI_OBJ_ID NUMBER(22) Enter the Table or view object ID.
- SRC_TI_OBJ_VER NUMBER(7) Enter the Table or view object version.
- SRC_TI_LABEL VARCHAR2(4000) Source table's already applied label to any given load.
- VW_TI_COMPANY_ID NUMBER(6) Enter the view Company ID.
- VW_TI_OBJ_ID NUMBER(22) Enter the view object ID.
- VW_TI_OBJ_VER NUMBER(7) Enter the view object version.
- PI_WA_TABLES_COLL (Optional) This is a parameter of type CDR_WA_TABLES_TYPE
that contains table naming attributes.
Use this parameter if the API call is intended to set the label for only a subset of table(s) of an Work Area. It contains following naming attributes:
- TI_COMPANY_ID NUMBER(6) Table COMPANY_ID to which label need to be set.
- TI_OBJ_ID NUMBER(22) Enter the object ID for the Table for which the label needs to be set.
- TI_OBJ_VER NUMBER(7) Enter the object version for the Table for which the label needs to be set.
- TI_RET_STATUS VARCHAR2(4000) This is return status, should be passed as null.
Functional Rules
The following rules outline the API's behavior depending on parameter usage in the API call:
- If PI_WA_TABLES_COLL is used, it will apply the label only to the entered table(s) and/or view(s).
- If PI_WA_TABLES_COLL is null, the label is applied to all table(s)/view(s) in the Work Area.
- Multiple labels cannot be applied to the same table/view in one API call.
- If PI_DATE is used, the label is applied to the latest Table data load, less than equals to the used date.
- If PI_DATE is not used, the label is applied to latest Table data load.
- If PI_FORCEFLAG is set to $YESNO$YES, the API overwrites the Snapshot Label if already applied, otherwise the label is not applied.
- If PI_FORCEFLAG is set to $YESNO$YES, non-blinded Tables are always included to be labeled.
- If PI_SRC_TAB_COLL is null, and PI_WA_TABLES_COLL has view information or is null (if view exists), the view is loaded and labeled with latest loaded data from the source table.
- If PI_SRC_TAB_COLL has a partial set of source table or views, and PI_WA_TABLES_COLL has view information, the view is loaded and labeled with the latest loaded data from the source table that has non-passed source information.
- If PI_SRC_TAB_COLL is used, the view details should be part of PI_WA_TABLES_COLL.
- If PI_SRC_TAB_COLL is null label will be applied to all table(s) in given Work Area.
- If collection PI_SRC_TAB_COLL is passed with source table's label then view will be loaded and labeled with that data of source table.
- If PI_SRC_TAB_COLL is used with the source table's label as null, then the view is loaded and labeled with latest loaded data of source table.
Use this API to remove a snapshot label from the passing Work Area.
Name
CDR_PUB_EXE_SNAPSHOT.RemoveLabel
Signature
PROCEDURE REMOVELABEL( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, PI_WA_COMPANY_ID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_WA_OBJ_ID IN CDR_NAMINGS.OBJ_ID%TYPE, PI_WA_OBJ_VER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE, PI_WA_TABLES_COLL in OUT NOCOPY CDR_WA_TABLES_COLL, PI_LABEL IN CDR_TAB_REF_LABELS.LABEL%TYPE, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
- PI_WA_TABLES_COLL (Optional) User can pass the collection of table instance of the same Work Area on which user want remove the Snapshot Label.
- PI_LABEL (Mandatory) Label value.
