4 Adding and Modifying Lookup Values
This chapter contains the following topics:
- About Lookups
Oracle Life Sciences Data Hub uses predefined lists of values for many items such as drop-down lists in the user interface. - Modifiable Lookups
You can modify the following lookups in Oracle Life Sciences Data Hub: - Logging In
To modify lookup values, do the following: - Querying and Viewing Lookups
To view a lookup, or reference codelist, query for it as follows. Further information is available in the online help. - Adding, Modifying, or Discontinuing a Lookup Value
Depending on the access level assigned to a lookup, you may be able to change its displayed text (the "Meaning") and add, modify, and discontinue existing values.
About Lookups
These are based on lookups in the seed data shipped with Oracle LSH. You can modify some of these lists of values.
Many database object type attributes used in Oracle LSH public APIs have lists of values based on these lookups (also called reference codelists); the naming convention is to end these attributes' names with _rc. You can use the procedures in this section to look up the allowed values for these attributes.
To view or modify Oracle LSH lookups, you must have the LSH Setup Admin privilege.
The changes you can make depend on the access level defined for each lookup:
- System. You cannot change anything.
- Extensible. You can create additional values and modify them but you cannot modify predefined ones.
User. You can create additional values and change the text displayed in the user interface for existing values (the "meaning"), and discontinue the use of predefined and user-defined values.
If you change the text displayed in the user interface for existing values, the Oracle LSH documentation and online help will not reflect what is in the user interface, which may cause confusion.
Parent topic: Adding and Modifying Lookup Values
Modifiable Lookups
- File Types
- Font Name
- OTD Default Papersize
- Report Type
- SAS IDE Client
- Service Type
- Summary Output Validation Status
- System Validation Steps
- Tablespace Names
- Technology Types
File Types
(CDR_FILE_TYPES) The access level is Extensible. This lookup is used in defining Source Code types; see "Defining Programs" in the Oracle Life Sciences Data Hub Application Developer's Guide. The predefined values are Macro, Program, Oracle Reports, and SQL.
Parent topic: Modifiable Lookups
Font Name
(CDR_FONT_NAME) The access level is User. This lookup is used in Report Set post-processing; see "Defining Report Sets" in the Oracle Life Sciences Data Hub Application Developer's Guide. The predefined values are Arial and Courier. If you prefer to use different fonts in your PDF Report Sets, you can add those fonts as values.
(CDR_OTD_DEFAULT_PAPERSIZES) The access level is User. This lookup is used in Report Set post-processing; see "Defining Report Sets" in the Oracle Life Sciences Data Hub Application Developer's Guide. The predefined values are A4 and US Letter.
Report Type
(CDR_REPORT_TYPE) The access level is User. This lookup is used in Report Set definition; see "Defining Report Sets" in the Oracle Life Sciences Data Hub Application Developer's Guide. The predefined values are Figure, Listing, and Table.
SAS IDE Client
(CDR$SAS_IDE_CLIENT) The access level is User. This lookup allows users to set a preference for which SAS client to use. There is one predefined value: SAS PC, which allows users to use PC SAS for Windows. If you want users to be able to use SAS Enterprise Guide, for example, add another meaning value of SAS EG with a code value of $SAS_IDE_CLIENT$SAS_EG.
If you do not want your users to use PC SAS and do not want the SAS IDE Client option to appear in User Preferences, delete the SAS PC value. If you want to add it again later, you must enter its code value as: $SAS_IDE_CLIENT$SAS_PC.
To delete the value, select it and select Delete from the Edit menu. Do not delete the lookup itself.
Service Type
(CDR_SERVICE_TYPES) The access level is
Extensible. This lookup is used in defining services; see
Setting Up Services. The predefined values are: BI Publisher, BI Publisher Development,
Zip Utility, OBIEE Business Area Deploy Service, OBIEE Deployment Service, OBIEE
Business Area IDE Service, OBIEE Business Area Install Service, Oracle Export, Oracle
Warehouse Builder, PLSQL, PLSQL for Development, Oracle Reports for Development, Oracle
Reports, SAS, SAS for Development, SQLPLUS, Text for SqlLoader, Workflow, XML Publisher,
and XML Reports.
(CDR_SOVS) The access level is User. This lookup is used in Report Set validation; see "Defining Report Sets" in the Oracle Life Sciences Data Hub Application Developer's Guide. The predefined values are Development, Quality Control, Production, Unassigned, and Not Applicable. You can change the displayed text for the existing values (in the Meaning column) but do not add values.
(CDR_SYS_VALIDATION_STEPS) The access level is User. This lookup is used in object validation; see "Common Development Tasks" in the Oracle Life Sciences Data Hub Application Developer's Guide. The predefined values are Development, Quality Control, Production, and Retired. You can change the displayed text for the existing values (in the Meaning column) but do not add values.
Tablespace Names
(CDR_TABLESPACE_NAMES) The access level is Extensible. When users define a Table instance, they can select a tablespace for it; see "Defining Tables" in the Oracle Life Sciences Data Hub Application Developer's Guide. The predefined values are APPS_TS_ARCHIVE, APPS_TS_MEDIA, and APPS_TS_TX_DATA.
Technology Types
(CDR_TECH_TYPES) The access level is Extensible. This lookup is used in Load Set, Data Mart, Business Area, Program, Report Set, and Workflow definition and execution. The predefined values are Oracle Clinical Design Definition, Oracle Clinical DX Views, Oracle Clinical DX SAS Views, Oracle Clinical General, Oracle Clinical Global Meta, Oracle Clinical Labs, Oracle Clinical Study, Oracle, Oracle Export Data Mart, PLSQL, Oracle Reports, Report Set, SAS Program, SAS Macro Catalog, SAS Data Mart, SAS Development, SAS Format Catalog, SAS Load Set, SAS tmp, SQLP, Text, Text Data Mart, Workflow, XML Publisher.
If you add an adapter to an external system you need to add the new technology type to this lookup.
Logging In
- Open your Oracle Life Sciences Data Hub URL and log in as a user with the LSH Administrator application role.
- From the Navigator drop-down, select LSH Setup Admin, then Setups, then Lookups. An Oracle Applications window opens with the Oracle Life Sciences Data Hub Lookups window displayed.
The following information is displayed for each value:
- Code is the internal name for the value.
- Meaning is the text that appears on the user interface, exactly as it appears here.
- Description is an explanation of the value.
- Tag is an optional descriptor.
- Effective Dates. The From column contains the date the value was created in your location. The To column may contain a date; if so, this is the date on which the value became or will become unavailable for use. If there is not a date in either column, the value is in effect.
See Modifiable Lookups.
The Lookups user interface is part of Oracle Applications functionality not specific to Oracle LSH. Additional information is available in the online help.
