Assemble the Documentation
Installing Oracle LSH is a complex process because it includes installing, upgrading, and patching a number of other products. This book guides you through the process, but refers you to the documentation for other products along the way.
Oracle recommends that you gather all the documentation you will need and read it before you begin the process of installing Oracle LSH.
Parent topic: Before You Begin
Books
The books you need to install the technology stack are included in the media pack.
You can also find PDF and HTML copies online; see Documentation accessibility.
In addition to this guide, you need:
- Oracle Life Sciences Data Hub System Administrator's Guide Release 2.5
- Oracle Thesaurus Management System Installation Guide Release 5.3
- Oracle E-Business Suite Release 12.1.1 Documentation Library which includes:
- Oracle E-Business Suite Maintenance Utilities
- Oracle E-Business Suite Maintenance Procedures
- Oracle E-Business Suite Patching Procedures
- Oracle E-Business Suite System Administrator's Guide - Configuration
Oracle E-Business Suite System Administrator's Guide - Maintenance
- Oracle E-Business Suite System Administrator's Guide - Security
- Oracle® Applications Upgrade Guide Release 11i to 12.1.1
- Oracle E-Business Suite Installation Guide: Using Rapid Install Release 12
- Oracle Warehouse Builder Installation and Administration Guide 11g Release 2 (11.2)
- Oracle Warehouse Builder Release Notes 11g Release 2 (11.2)
- Oracle Business Intelligence Publisher Installation Guide Release 10.1.3.4
- Oracle Fusion Middleware Installation Guide for Oracle Business Intelligence 11g Release 1 (11.1.1)
- Oracle Fusion Middleware Upgrade Guide for Oracle Business Intelligence 11g Release 1 (11.1.1)
In addition, if you plan to integrate Oracle LSH with any of the systems listed in Integrating Other Systems, you need the installation guide and user documentation for those systems.
The rest of the Oracle LSH user documentation is also included. However, you should check Oracle Help Center for the most current versions.
Parent topic: Assemble the Documentation
My Oracle Support Articles
The My Oracle Support Web site contains links to the most recent patches and updates for Oracle products. This section lists all the My Oracle Support articles listed in subsequent sections of this guide so that you can copy all of them to one place. See Documentation accessibility.
- System Requirements and Technology
- Installing Oracle Applications and Oracle Database
- Installing Oracle Life Sciences Data Hub
- Upgrading to Oracle Life Sciences Data Hub Release 2.5
- Other Documents Related to Oracle Life Sciences Data Hub
System Requirements and Technology Stack references the following My Oracle Support articles:
- 180430.1, Oracle Life Sciences Applications Supported Technology Stacks
Parent topic: My Oracle Support Articles
Installing and Patching Oracle Applications and Oracle Database references the following My Oracle Support articles:
- 1138053.1, Oracle Life Sciences Data Hub and Oracle Clinical Development Analytics Known Install and Configuration Issues
- 1058763.1, Interoperability Notes Oracle E-Business Suite Release 12 with Oracle Database 11g Release 2 (11.2.0)
- 387859.1, Using AutoConfig to Manage System Configurations in Oracle E-Business Suite Release 12
- 406982.1, Cloning Oracle Applications Release 12 with Rapid Clone
- 455999.1, How to Verify if OWB is Installed Correctly on RAC and Exadata
- 403537.1, Secure Configuration Guide for Oracle E-Business Suite Release 12
Installing Oracle Life Sciences Data Hub references the following My Oracle Support articles:
727208.1, AuditTrail Update Tables fails on View AP_SYSTEM_PARAMETERS_ALL_AC1
164871.1, Configuring the Workflow Notification Mailer in Oracle Applications Manager 11i
Upgrading to Oracle Life Sciences Data Hub Release 2.5 references the following My Oracle Support article:
- 1054417.1, Patch 6678700 Worker Fails On Applying MSDODPCODE.sql With ORA-33292 Insufficient Permissions To Access Analytic Workspace APPS.ODPCODE; ORA-33262: Analytic workspace ODPCODE does not exist.
- 1314218.1, ORA-37002: Oracle OLAP failed to initialize while applying patch 6678700
- 296187.1, How To Manually Install Oracle OLAP into a 9i, 10g or 11g database After the DB Has Been Created
- 1333659.1, Applying The Patch 6678700 Worker 1 Failed: File Cskbcat.Ldt. ERRORS: ORA-20000: Oracle Text error: DRG-50857: oracle error in textindexmethods.ODCIIndexUpdate, DRG-13201: KOREAN_LEXER is desupported
- 1281478.1, Script Czhist.Sql Fails During Application Of Patch 6678700
- 1083981.1, Script Pechktsk.Sql fails with, ORA-00979: Not A Group By Expression when applying Patch 6678700 or Patch 3500000
- 1322144.1, Error - ORA-54015 : biv_b_age_h_sum_mv.xdf Failes with Duplicate Column Expression was Specified
- 1284055.1, 12.1.1 Upgrade Fails on Fem_bal_nacc_hier_l2_mv.xdf with Oracle 11.2.0.2 Database
- 1106795.1, adapcctl.sh: exiting with status 150
- 1358564.1, OWB Import of Entire Repository Fails with ORA-00001: Unique Constraint (OWBSYS.ET_PK) Violated
- 1058763.1, Interoperability Notes EBS 12.0 and 12.1 with Database 11gR2
The following related documents are available on My Oracle Support. See Documentation accessibility.
- Oracle Life Science Data Hub (LSH) Summary of Patches Available (1376925.1)
- Oracle Life Sciences Data Hub 2.1.3, 2.1.4, 2.2, 2.3, 2.4, and 2.5 Installation Verification Tests (1063225.1)
- Guide to Using Oracle VM Templates in an Oracle Life Sciences Data Hub 2.2 Installation (1450700.1)
- Oracle Life Sciences Data Hub 2.2 Data Guard Support (1342251.1)
- Oracle Life Sciences Data Hub Release 2.2 Performance Behavior and System Recommendations (1369871.1)
