Upgrade to Oracle Life Sciences Data Hub 2.5
These steps are required for all upgrade paths.
- Database Tier Preinstallation Steps
- Apply the Oracle Warehouse Builder (OWB) Patch
- Install Oracle Life Sciences Data Hub 2.5
- Change Your FND_Validation_Level Profile
Parent topic: Upgrading to Oracle Life Sciences Data Hub Release 2.5
- Stop the Message and Job Queues
- Abort the Long-Running Jobs
- Cancel the Sessions Holding Locks on Application Objects
- Disconnect Blocking Sessions
Parent topic: Upgrade to Oracle Life Sciences Data Hub 2.5
Parent topic: Database Tier Preinstallation Steps
Apply OWB patch 18146494 before installing the 2.5 release for Oracle LSH and Oracle DMW. You can download the patch and access the Readme on My Oracle Support (https://support.oracle.com).Parent topic: Upgrade to Oracle Life Sciences Data Hub 2.5
Follow the instructions in the Install Oracle LSH 2.5 and Install Online Help topics.
Change the setting of the FND_Validation_Level profile. In previous releases a setting of NONE was required, but now a setting of ERROR is required.
