Adding Lookup Values
You must extend certain lookups. You can also enable your customers to add lookup values in their own environment.
Extend the following lookups:
- CDR_TECH_TYPES. At least one new technology type is required for your adapter. Enter the same value that you enter in the pio_techTypeRow.TECH_NAME_RC parameter of the Create Technology Type API. This value is used internally.
- CDR_SERVICE_TYPES. One service type per technology type is required. This value appears in the user interface for defining services.
- CDR_FILE_TYPES. Your adapter may need need a new file type; for example, for source code in Program or Business Area adapters. Add the file type to this lookup.
For instructions on extending lookups in your environment, see the chapter on lookups in the Oracle Life Sciences Data Hub System Administrator's Guide.
Provide instructions to each company using the adapter for adding the lookup values required for your adapter in their own environment.
Parent topic: Designing an Adapter
