Planning Planned Outputs
Data Mart adapters may require predefined Planned Outputs to support the actual data file produced by running the Data Mart.
Program adapters may required predefined Planned Outputs to support report outputs.
Data Mart, Program, and Load Set adapters may all need predefined Planned Outputs to serve as placeholders for other outputs created when they are executed; for example, log and error files.
To automatically create a fixed Planned Output definition for every object of your adapter's object type (Data Mart, Program, or Load Set), call public API CDR_PUB_DF_PLANNED_OUTPUT.CREATEPLANNEDOUTPUT in your define_time_function.
Parent topic: Designing an Adapter
