Call the Create Column API
Call the API CDR_PUB_DF_TABLE.CREATECOLUMN to create Columns for the Table, one at a time.
You can create both the Column and the Variable on which it is based at the same time.
- PIO_NAMING. Enter CDR_NAMING_VERSION_OBJ_TYPE values as follows:
- company_id =
Enter_your_company_ID - obj_id = null
- obj_ver = null
- object_type_rc =
'$OBJTYPES$COLUMN' - name = '
Enter_a_name_for_the_Column' - namespace_obj_id =
Enter_the_Table's_obj_ID - namespace_obj_ver = 1
- namespace_start_obj_ver = 1
- namespace_end_obj_ver=
cdr_def_constants.cdr_max_def_object_version - owning_location_rc = null
- checked_out_flag_rc =
'$YESNO$NO' - checked_out_id = null
- object_subtype_id = null
- description =
'Enter_a_Description_for_the_Column' - copied_from_company_id = null
- copied_from_obj_id = null
- copied_from_obj_ver = null
- ref_company_id = null
- ref_obj_ver = null
- object_version_number = 1
- status_rc =
'$NAMING_STATUS$INSTALLABLE' - validation_status_rc = null
- version_label = null
- company_id =
- PIO_VARIABLE. Enter CDR_VAR_OBJ_TYPE values to define the Variable as follows:
- company_id =
- obj_ver = 1
- oracle_name =
'Enter_an_Oracle_name_for_the_Table' - oracle_datatype =
'Enter one: $ORADATATYPES$VARCHAR2, $ORADATATYPES$NUMBER, $ORADATATYPES$DATE' - length =
'Enter_a_length_for_the_Table' - precision =
'If_your_Variable's_datatype_is_NUMBER,_enter_its_precision' - sas_v6_name =
'Enter_your_variable's_SASv6_name_(up_to_8_chars)' - sas_v8_name =
'Enter_your_variable's_SASv8_name_(up_to_32_chars)' - sas_label =
'Enter_your_variable's_SAS_label_(up_to_256_chars)' - sas_format =
'Enter_your_variable's_SAS_format' - nullable_flag =
'Enter_$YESNO$YES_if_the_value_can_be_ null_or_$YESNO$NO_if_not' - default value =
Set_to_Null_or_enter_a_default_value_for_the_variable
- company_id =
- PIO_COLUMN. Enter CDR_COLUMNS_OBJ_TYPE values to define the Variable as follows:
- company_id =
- obj_ver = 1
- position_number =
'Enter_your_column's_position_number_in_the_Table' - nullable_flag =
- company_id =
- PI_CREATETYPE Enter
BOTHto create a Variable and a Column at the same time. - PI_DEFCLASSIFICATIONCOLL Null
Parent topic: Creating a Table Definition
