Components and the User Interface
Your adapter allows Oracle Life Sciences Data Hub Definers to create a new type of Load Set, Program, Data Mart, or Business Area.
Figure 1-2 Selecting the Adapter Type During Object Creation
Description of "Figure 1-2 Selecting the Adapter Type During Object Creation"
When a Definer creates an object of any type, he or she must select an adapter type. The system adds the name you define for the Adapter Area to the list.
Figure 1-3 Object Properties User Interface
Description of "Figure 1-3 Object Properties User Interface"
The above "screenshot" is an amalgam of buttons and options from different object types and states.User interface elements for all objects interact as follows with adapter components:
Parent topic: About Adapters
