Object Installation Functions
Depending on the external system, you may need to write functions for use when a user installs a Load Set, Data Mart, Program, or Business Area. All object installation function names are stored in the tech_types table.
Each function should return TRUE in case of success and FALSE in case of a failure. All three of these functions must have the following signature:
functionname_of_function(company_id in cdr_program_refs.company_id%TYPE,prref_id in cdr_program_refs.prref_id%TYPE,prref_ver in cdr_program_refs.prref_ver%TYPE, )return boolean
The functions' parameters take values as follows:
pi_nCompanyID see "Getting Your Company ID"
prref_id see "Getting an Object's Prref_Id and Prref_Ver"
prref_ver see "Getting an Object's Prref_Id and Prref_Ver"
See details for the following functions:
