Enforcing Security on Corresponding External Entities
You may need to create entities in the external system that correspond to Oracle Life Sciences Data Hub objects.
For example, the OBIEE adapter creates a different OBIEE Subject Area for each OBIEE Business Area. You can then use the external system's security to enforce access to the appropriate external system entities.
You can use the Security_Recalc_Function to synchronize security in your adapter.
You can use the Tracking API and Tracking Table to maintain a record of the object the same user accessed during his or her previous session in the IDE and then use the security APIs of the external system to remove access to that object in the current session; see Tracking and Removing Object Access.
Parent topic: Synchronizing Security with Integrated Environments
