Planning Integrated Development Environment Adapters
There are a number of things your Definers may need to be enabled to do in an integrated development environment (IDE). You must consider these needs when planning IDE adapters.
Business Area and Program adapters may require that Oracle Life Sciences Data Hub Definers be able to do the following in a development environment that is integrated with Oracle LSH:
- Launch the integrated development environment (IDE) from within Oracle LSH either from the Program or Business Area Properties page (for development) or from the Reports tab, Visualizations subtab (for viewing data visualizations), and then see appropriate Oracle LSH data in the IDE.
- Download and upload files between Oracle LSH and the IDE—or the adapter may need to do this automatically.
- Log in directly to the external system and gain access to Oracle LSH objects and data.Oracle LSH allows this access only for adapters that view but do not modify Oracle LSH data. In this case, you can use the generic visualization adapter; see Using the Generic Visualization Adapter.
For more information, see the following:
