Planning Navigation in the External System to Business Areas
You can use the view CDR_PUB_GENERIC_BA_V to make the Oracle Life Sciences Data Hub object hierarchy—from Domains to Application Areas to Work Areas to Business Areas—to which the current user has access, available in the external system.
You can then use it to create a display in the external system's user interface that helps users find what they need; see Display User's Business Area Instances.
The user must log in using the database account.
This works only if you give the objects in the hierarchy meaningful names.
Parent topic: Planning Integrated Development Environment Adapters
