Launching the Visualization Tool
You need to provide the URL required to launch the visualization tool and write a function (see Build_IDE_Cfg_Function) that is tracked in the Tech Types table.
For some external visualization systems (for example, OBIEE), you may need to access the external system in one mode from the Business Area UI and in another mode from the Visualizations subtab of the Reports tab. Oracle Life Sciences Data Hub calls the build_ide_cfg_function in both cases, but detects whether the user is in the Business Area or in the Reports tab and calls the appropriate environment.
