Modifying an Adapter Area
If you need to modify your Adapter Area, use public API CDR_PUB_ATK_ADAPTER.MODIFYADAPTERAREA.
Its signature is:
Package cdr_pub_atk_adapter PROCEDURE modifyAdapterArea( p_api_version IN NUMBER ,p_init_msg_list IN VARCHAR2 default CDR_PUB_DEF_CONSTANTS.G_FALSE ,p_commit IN VARCHAR2 default CDR_PUB_DEF_CONSTANTS.G_FALSE ,p_validation_level IN NUMBER default CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL ,x_return_status OUT NOCOPY VARCHAR2 ,x_msg_count OUT NOCOPY NUMBER ,x_msg_data OUT NOCOPY VARCHAR2 , pio_adapterAreaNaming IN OUT NOCOPY cdr_naming_version_obj_type , pio_adapterAreaRow IN OUT NOCOPY cdr_adapter_areas%rowtype ) ;
See the description of the parameters in Creating an Adapter Area.
Parent topic: Using APIs to Create Required Metadata Objects
