Sample Adapter Settings
The following table shows the Adapter Area settings used by some of the adapters shipped with Oracle Life Sciences Data Hub.
You can see all settings for the shipped adapters in CDR_ADAPTER_AREAS_V.
The system treats No and Null the same way.Table 4-2 Sample Adapter Settings
| Column Name | Oracle Tables and Views Load Set Adapter | Text Load Set Adapter | SAS Load Set Adapter | SAS Data Mart Adapter | Generic Visualization Business Area Adapter |
OBJ_VER |
1 |
1 |
1 |
1 |
1 |
ADAPTER_NAME |
ORACLE_DATABASE |
Text |
SAS |
SAS EXPORT |
GENERIC_VISUALIZATION |
ADAPTER_VERSION |
1 |
1 |
8.2 |
1 |
1.0.1.2 |
ADAPTER_TYPE |
LOADSET |
LOADSET |
LOADSET |
DATAMART |
BUSAREA |
TECHNOLOGY_TYPE_ID |
(Generated) |
(Generated) |
(Generated) |
(Generated) |
(Generated) |
ALLOW_COLUMN_UPLOAD |
File |
COLUMN_UPLOAD_FUNCTION |
CDR_ATK_OracleDB_Services.UploadColumns |
Null |
CDR_ATK_SAS_Services.UploadOperatorColumns |
Null |
ALLOW_MANUAL_TAB_DESC_FLAG |
AUTO_ADD_TAB_DESC_LOV |
CDR_ATK_OracleDB_Services.CreateMultipleOperators |
ALLOW_AUTO_ADD_TAB_DESC |
AUTO_ADD_TAB_DESC_FUNCTION |
CDR_ATK_OracleDB_Services.GetDataOperList |
Null |
Null |
Null |
CURRENCY_FUNCTION |
Null |
Null |
Null |
Null |
DEFINE_TIME_FUNCTION |
CDR_ATK_OracleDB_Services.CreateLogFilePlannedOutput |
CDR_ATK_Text_Services.CreateLogFilePlannedOutput |
CDR_ATK_SAS_Services.CreateLogFilePlannedOutput |
CDR_ATK_DM_SAS_SERVICES.createPlannedOutput |
Null |
DEFINE_TIME_CONNECT_FLAG |
INSTALL_TIME_CONNECT_FLAG |
RUNTIME_CONNECT_FLAG |
TABLES_AS_VIEWS_FLAG |
TABLES_AS_VIEWS_FUNCTION |
Null |
Null |
Null |
Null |
ACTIVE_FLAG_RC |
$YESNO$YES |
$YESNO$YES |
$YESNO$YES |
$YESNO$YES |
$YESNO$YES |
DEF_PARAM_FLAG_RC |
$YESNO$YES |
$YESNO$YES |
$YESNO$YES |
$YESNO$YES |
$YESNO$YES |
RUN_PARAM_FLAG_RC |
$YESNO$YES |
$YESNO$YES |
$YESNO$YES |
$YESNO$YES |
$YESNO$NO |
TD_PARAM_FLAG_RC |
$YESNO$YES |
$YESNO$NO |
$YESNO$NO |
$YESNO$NO |
$YESNO$NO |
STATUS_RECALC_FUNCTION |
Null |
Null |
Null |
CDR_ATK_DM_SAS_SERVICES.synchronizeDatamart |
Null |
SECURITY_RECALC_FLAG_RC |
$YESNO$NO |
$YESNO$NO |
$YESNO$NO |
$YESNO$NO |
$YESNO$NO |
SECURITY_RECALC_FUNC |
Null |
Null |
Null |
Null |
Null |
INSTALL_SCHEMA_FLAG_RC |
$YESNO$YES |
$YESNO$NO |
$YESNO$NO |
$YESNO$NO |
$YESNO$NO |
INSTALL_SCHEMA_SUFFIX |
Null |
Null |
Null |
Null |
Null |
Parent topic: Creating an Adapter Area
