Adding the Direct SQL Option to SAS Libraries
his profile allows you to add the SAS option DIRECT_SQL=NOWHERE to your SAS libraries.
TThis SAS option prevents SAS WHERE clauses and PROC SQL-generated or -specified WHERE clauses from being passed to the DBMS for processing.
The default value is null, which has the same effect as a setting of NO: the DIRECT_SQL=NOWHERE is not included in your SAS libraries.
To add the option to your SAS libraries, do the following:
Parent topic: Setting Profile Values
