Allowing User Preferences for SAS Clients
This profile allows you to set the default User Preference for SAS client across your site and stores individual users' preferences.
Oracle Life Sciences Data Hub ships with a single value for the SAS IDE Client user preference: SAS PC, which supports PC SAS for Windows. If your users need to use a different SAS client, for example, SAS EG, you can extend the lookup SAS IDE Client to display additional clients on the Life Sciences Data Hub User Preferences screen. Users can then select the client they prefer.
If you do not set a default value, users are required to set a value in the User Preferences screen in order to launch any SAS client.To set the default SAS Integrated Development Environment (IDE) Client for your site, do the following:
Parent topic: Setting Profile Values
