Adding Levels to Hierarchies
You must define at least one level for every hierarchy.
You must define the topmost level first, then the next lower level, and so on.
To add a level, do the following:
To add a level after you have clicked Apply, click Update.
After creating a hierarchy, you must activate it before you can use it. See Activating the Hierarchy and Making it Usable or Unusable. You can remove and reorder a hierarchy level only if its owning hierarchy is not set to Active.
- Reorder Hierarchy Levels
To change the order of the levels in a hierarchy, do the following: - Remove Hierarchy Levels
To remove a level, select it and click Remove.
Parent topic: Creating and Maintaining Hierarchies
