Copy and Edit Revised Execution Command Scripts
The obieedeploy.cmd and obieeinstall.cmd command script files should be modified for Oracle Business Intelligence Enterprise Edition 12c integration. The templates for these command scripts are available under $cdr/admin/template.
The obieedeploy.cmd and obieeinstall.cmd command script files should be modified for Oracle Business Intelligence Enterprise Edition 12c integration. The templates for these command scripts are available under $cdr/admin/template. Copy the Oracle LSH versions of obieedeploy.cmd and obieeinstall.cmd from $cdr/admin/templates to the Oracle LSH Distributed Processing Server location and referred to in the Execution Command under the Oracle Business Intelligence Enterprise Edition Install and Deploy service configured in Oracle LSH under the Oracle Business Intelligence Enterprise Edition Service Location.
set PATH=%PATH%;C:\bi_home\bi\bifoundation\server\binset ORACLE_BI_APPLICATION=coreapplicationset ORACLE_BI_INSTANCE=C:\bi_homeset COMPONENT_NAME=coreapplication_obis1set COMPONENT_TYPE=OracleServerComponentset ORACLE_INSTANCE=C:\bi_homeset DOMAIN_HOME=C:\bi_home\user_projects\domains\bi
set RPD_DIR=C:\RPD
Parent topic: Setting Up Oracle Business Intelligence Visualizations
