11 Setting Up Oracle Business Intelligence Visualizations
When used with Oracle Life Sciences Data Hub, each OBIEE Subject Area is based on a single Oracle LSH Business Area with Table Descriptors that are mapped to Table instances.
When used with Oracle Life Sciences Data Hub, each OBIEE Subject Area is based on a single Oracle LSH Business Area with Table Descriptors that are mapped to Table instances. The OBIEE Subject Area displays the data contained in these Table instances. The Subject Area's name in OBIEE Answers is populated with the Business Area's name. Each Business Area is linked to an OBIEE Presentation Server. Users can launch OBIEE from inside Oracle LSH or through a URL for the Presentation Server linked to the Business Area.
The Presentation Server can support multiple Business Areas. Oracle LSH automatically merges the OBIEE repository (.rpd) file for each Business Area linked to the Presentation Server into one large .rpd file.
By default when you install the BI Server, a Presentation Server is also installed on the same computer. You must install the Oracle LSH Distributed Processing (DP) Server on this computer as well. All Business Areas defined in Oracle LSH then point to this Presentation Server. Oracle LSH merges the .rpd files for all Business Areas into a single large .rpd file.
This chapter contains the following topics:
- Setting Up the Configuration
In Oracle Life Sciences Data Hub you must define a service location for the BI Server computer. - Set Up Database Connectivity
To run Oracle Business Intelligence visualizations through Oracle Life Sciences Data Hub, you must set up connectivity between the Oracle LSH database and the BI Server database. - Copy and Edit Revised Execution Command Scripts
The obieedeploy.cmd and obieeinstall.cmd command script files should be modified for Oracle Business Intelligence Enterprise Edition 12c integration. The templates for these command scripts are available under $cdr/admin/template. - Starting the WebLogic Server
If the URL for Oracle Enterprise Manager or the WebLogic Administration Console is not working, the WebLogic Server may be down. - Set Up Oracle Business Intelligence Administration Tool
To use the Oracle Business Intelligence Administration Tool, each Definer must do the following on his or her local PC: - Security Configuration
