Set Up Oracle Business Intelligence Administration Tool
To use the Oracle Business Intelligence Administration Tool, each Definer must do the following on his or her local PC:
- Install Oracle Business Intelligence Client Tools in the location specified by the system administrator; this location must be specified in cdrconfig.xml; see the section on installing the client plug-in in the Oracle Life Sciences Data Hub Installation Guide.
- Insert the CD-ROM supplied by the system administrator.
- Ensure that cdrconfig.xml has the correct directory path for the Oracle BI Administration tool.
- In the Oracle BI Administration Tool, set up connectivity with the Oracle LSH database. See Set Up Database Connectivity for information.
Add and set the following environment variables on the PC through advanced system properties:
- ORACLE_HOME Enter the absolute path of the Oracle Home on your PC; for example:
C:\Program Files\Oracle Business Intelligence Enterprise Edition Plus Client\oraclebi\orahome
- ORACLE_INSTANCE Enter the absolute path to Oracle BI orainst1 on your PC; for example:
C:\Program Files\Oracle Business Intelligence Enterprise Edition Plus Client\oraclebi\orainst
- ORACLE_BI_APPLICATION You must enter the following value exactly:
coreapplication
Parent topic: Setting Up Oracle Business Intelligence Visualizations
