System Administrator's Guide Setting Up Oracle Business Intelligence Visualizations Security Configuration Creating an OBIEE Remote Location and Connection for RPD Password Security Create an OBIEE Remote Location Connection Create an OBIEE Remote Location Connection For each OBIEE Remote Location, create a Remote Connection. To define a Connection: In the main screen for the Remote Location for which you want to create a Connection, click Create Connection. The Create Connection screen opens. Enter values in the following fields: Name. Enter administrator. (Not case-sensitive) Description. Not required. User Name. Enter administrator. Password. Enter the password you want to require for the .rpd file. Oracle Life Sciences Data Hub encrypts the password for security. Connection Type. The system does not use this value. Remote Location. The system populates the field with the name of the Remote Location for which you are defining this Connection. Classification: The system does not use these values. Click Apply to save your work. The system displays the main screen for the new Connection. Parent topic: Creating an OBIEE Remote Location and Connection for RPD Password Security
