Default Tablespace for Work Area Schema Objects
By default, Oracle LSH internal application tables and user-defined Work Area tables are controlled using internal profile values. To avoid performance and functional issues, do not change the values of the profile.
If you changed the tablespace size in past releases, do not make any further changes.Parent topic: Setting Profile Values
