Defining Services
This section includes the topics on service types, priorities, and instances.
For each service location, define services as follows:
- One or more services for each XML Publisher, SAS, Oracle Reports, and Oracle Business Intelligence Presentation Services instance engine installed on that computer
- One and only one service for PL/SQL as a processing engine
- One and only one service for each IDE service type
For the service location you specify the maximum number of jobs (across all services) that can run simultaneously.
For non-PL/SQL processing engine service types, you may want to define more than one service in order to allow jobs with different priorities to run on the same computer. For example, if you have both SAS and Oracle Reports installed on the same computer, you might define the following services for that service location:
- One high-priority SAS service with two instances allowed
- One normal-priority SAS service with seven instances allowed
- One normal-priority Oracle Reports service with five instances allowed
- Service Types
Some service types use the Distirbuted Processing (DP) Server and others do not. It depends on their definition requirements. - Service Prioritization
You must specify a priority for each service: High, Normal, or Low. - Service Instances
When you create a service, you must specify how many instances of the service are allowed to run at the same time.
Parent topic: Setting Up Services
