Duplicate Definition with Roles Only
You can create copies of a user group in two ways.
(Optional)To <manage/change/do something>:
- In the Security tab, click User Groups. The Manage User Groups screen appears.
- Enter a search string—the name of the user group you want to duplicate in the User Group box or text with the wildcard %, or leave blank to retrieve all user groups.
- Click Go. All the user groups matching the search criteria appear.
- Click the Select check box corresponding to the required user group.
- Click Duplicate with Roles. The system creates a copy of the user group and the Manage User Groups screen appears.
Parent topic: Duplicating User Groups
