Modifying User Groups
How to modify user groups
In the Manage User Groups screen, click the corresponding Update icon to modify a particular User Group. After you make the relevant changes, click Apply to save them or click Cancel to discard the changes.
You can modify the following characteristics:
  • Group Name
  • Description
  • Is Active. If selected, you can assign the User Group to an Object Subtype.
You can also add and remove Roles from the User Group; see Adding Supported Roles to User Groups.
