Modifying Object Security Roles
In the Manage Roles screen, click the corresponding Update icon to modify a particular Role.
After you make the relevant changes, click Apply to save them or click Cancel to discard the changes.
You can modify the following characteristics:
- Role Name. You can change the name of the role that appears in the Oracle Life Sciences Data Hub user interface.
- Description. You can change the description that appears in the Oracle LSH user interface.
- Is Active. If selected, you can assign the role to operations on object subtypes and a user group administrator can assign the role to a user in his or her user group.
Parent topic: Creating and Maintaining Object Security Roles
