Assigning Subtype Operations to Roles and Modifying Assignments
Subtype operations are predefined. They are the same as the predefined operations on their object type. You must assign at least one role to each operation; if no roles are assigned to the operation, no one will be able to perform the operation on objects of that subtype.
Users who are assigned to a particular role can perform operations on the subtype that are assigned to the same role, if the user is assigned to the role in the context of an active user group assigned to the object.
See the Oracle Life Sciences Data Hub Implementation Guide for information on how Oracle Life Sciences Data Hub security uses Roles and Operations.
In the Subtypes subtab in the Administration tab, you can see the relationship of roles to object operations two ways. Make your choice in the View Subtype By drop-down list:
  • Choose Operation to add a new role to operations or to add multiple roles to a single operation on a subtype at the same time.
  • Choose Role if you have already assigned the role to operations and want to view or modify the role's assignments.
