To assign roles to operations, go to the Subtype subtab of the Security tab and do the following:
Select Operation from the View Subtype By drop-down list.
Expand the node (+) of the object type. All the subtypes appear.
Expand the node (+) of the object subtype. All the subtype's operations appear.
Click the icon in the Manage column of the operation to which you want to assign or remove a role. The Add Role(s) to Operation screen appears.
Double-click on a role in the Available Roles column to move it into the Selected Roles column and assign it to the role. Or move it from Selected Roles to Available Roles to remove the assignment.
You can also select multiple roles by using Shift+Click or Control+Click and use the arrows to move one, a few, or all at once to the column in the shuttle.
You can change the order of the operations using the Up and Down arrows on the right. The display order has no functional effect.
Click Apply. The system assigns the role(s) to the operation on the subtype and the Manage Subtype screen appears.
